Indicator lights and horn intermittently working
- kw750kz
08 Aug 2012 15:35 #541390
by kw750kz
Indicator lights and horn intermittently working was created by kw750kz
I'm new to the forum and I'm hoping I can find someone to help me with this issue. The signals and horn on my '81 KZ750 LTD are intermittently working. Sometimes they're flawless, other times I get nothing at all. I'm pretty handy with mechanical issues but electrical issues baffle me. I've been over the wiring a few times and all the fuses and connections seem clean and correct. I can't find anywhere that a short or exposed wire might be causing the issue. Does anyone have any advice or the name of a good contact in central Indiana that I could take the bike to? If I had more time, I'd like to try and find the issue myself but as it stands I'm ready for some expert advice. Thanks for any help!
- Thank you received: 2098
08 Aug 2012 15:40 #541391
by Patton
Replied by Patton on topic Indicator lights and horn intermittently working
Would suggest having the battery load-tested, after adding water as needed and charging overnight.
And assure integrity of the ground connection where the negative battery cable attaches to rear of the engine.
08 Aug 2012 15:46 #541392
by Patton
If needed, there are wiring diagrams in KZr's FILEBASE.
Attachment filebasekzr.jpg not found
- kw750kz
08 Aug 2012 16:36 #541406
by kw750kz
Replied by kw750kz on topic Indicator lights and horn intermittently working
Thanks Patton, I used the wiring diagram in trying to find the issue. Still no luck.
08 Aug 2012 17:04 - 08 Aug 2012 17:05 #541416
by Patton
The first thing to do is assure that the battery is up to snuff, and properly grounded to the engine, and also that the battery cable terminals are clean and snugly connected to the battery posts.
The horn itself may be tested by using test wires to connect its terminals directly to the battery posts, whereupon it should toot.
If a new flasher is required, would get an automotive unit from the local auto supply store such as AutoZone, etc. There are two different types of flashers. A cheaper heat-operated style (as equipped in most stock bikes). And a superior electric-operated style, which is slightly more expensive.
And of course the standard advice about cleaning all the wiring connections.
Last edit: 08 Aug 2012 17:05 by Patton.
- MFolks
- Thank you received: 540
08 Aug 2012 17:27 #541422
by MFolks
Replied by MFolks on topic Indicator lights and horn intermittently working
Cleaning Motorcycle Electrics
1. Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. It can be purchased at most Radio Shack Stores or any electronic supply places. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
2. On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
3. Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
4. However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
5. Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
6. Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
7. Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
8. If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
9. The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start. The older Kawasaki’s have reports of the soldered connections crumbling, if your bike has this problem, just ask, as I’ve got a repair procedure for this.
10. Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
11. The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
12. If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you, along with boating supply stores.
13. Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
14. All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
15. Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
16. If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation. Inspect all heavy duty battery cables and the smaller wire terminations(Bullet Connectors), for failed crimps, and those used in the electrical connectors, as they can fail over time.
17. Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
18. The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
20. The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
21. Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
22. Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
If you suspect failed or failing solder joints in the handlebar switches, I've got a repair procedure for that, just ask....
