- Thank you received: 8
750 spectre only can get 6.0000 rpm's
- rcook52459
02 Aug 2012 00:30 - 02 Aug 2012 00:32 #540137
by rcook52459
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
750 spectre only can get 6.0000 rpm's was created by rcook52459
have a 83 750 spectre and when it gets to 6 grand feels like a rev-limiter is on it.what is the rpm limit?cleand the carbs 3 times.bike runs great untill 6 grand.has mechanical advance lube all pivot points on it.just feels like a rev-limiter.
Last edit: 02 Aug 2012 00:32 by rcook52459.
- Motor Head
- Thank you received: 391
02 Aug 2012 00:41 #540143
by Motor Head
Replied by Motor Head on topic 750 spectre only can get 6.0000 rpm's
Should spin 9K no problem.
Maybe your feeling a fuel restriction. Try opening the cap on the Tank, also see if the PetCock screen is partially blocked. Possible In-line filter is restricting flow, or there mat be screens above the Needle and seat for the Float Valve. Some carbs have them. Fuel level in carbs should be checked using the clear tube test.
- MFolks
- Thank you received: 540
02 Aug 2012 00:41 #540144
by MFolks
Replied by MFolks on topic 750 spectre only can get 6.0000 rpm's
I don't believe the Spectre's had a rev limiter. Is the bike suffering from fuel starvation? Air filter clean? Running individual"Pods" on the carbs? How's the sparkplugs look? Black is to rich, White too lean, but a light tan is about right. Using any of the "E" (Ethanol) gas?
- DiamondSkyBlue1000
- Thank you received: 40
02 Aug 2012 01:52 #540163
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic 750 spectre only can get 6.0000 rpm's
Didn't we have a guy on here not long ago that had a similar problem and it turned out to be the breather that comes off either the valve cover or the transmission? I can't remember which now but it was plugged and his case was getting pressurized and causing something like this. There was another guy that had a vacuum operated petcock and he was losing vacuum to it at high RPM's and it would shut off every time. Was it connected to the wrong place?
That was a head scratcher :laugh:
Those later year bikes had some different emissions stuff. Best to read up on it in the manual.
- rcook52459
02 Aug 2012 09:14 #540213
by rcook52459
Replied by rcook52459 on topic 750 spectre only can get 6.0000 rpm's
think the emissions stuff has been taken off.there is a hose just between the 2 cylinders.stock air cleaner.running a little rich.ethanol gas is all i can get.fuel lines are not bent or resricted(hwould have to take carbs off the check float blow screens.i went out and i can rev it past 7 grand just sittlin in netural.i.ve taken petcock out to look at screen ,it was clean.vaccum line to petock on # 3 carb vaccum port.have treid running without aircleaner in it ran worse.air cleaner should be changed(couldn't find one locally).thank you for your help
- Motor Head
02 Aug 2012 09:55 #540217
by Motor Head
Definitely change the Air Filter Element, if dirty.
You can get one here, www.z1enterprises.com/
- rcook52459
02 Aug 2012 11:04 #540234
by rcook52459
i;ll get an air filter.ordered colortune kit and should get it today to make sure a/f screws adjusted right.carbs are synced.vaccum ports on carbs have been plugged where emission lines went and air box has been plugged where emission line went.
- rcook52459
09 Aug 2012 10:21 #541537
by rcook52459
thank you all for your help.air filter dirty,#1 float level was off and #2carb was leaking at boot.now time to change the steering stem bearing,then ride
