Oops... broke my kz750
  • Carr_113
  • Carr_113's Avatar Topic Author
01 Aug 2012 13:58 - 01 Aug 2012 14:07
#540003
...accidentally snapped the head off of the bolt grounding the negative battery lead to the engine on my '80 KZ750E. It just crumbled into my hand - or i just grossly underestimated my own strength... Any suggestions for another good spot to attach the ground before I start drilling the remnants out? Thanks in advance!
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
'79 XS650 (needs love)
'72-'73 CB350 (3 or 4, in pieces)
Last edit: 01 Aug 2012 14:07 by Carr_113.
  • Del_Herring
  • Del_Herring's Avatar
Re: Oops...
01 Aug 2012 14:07
#540005
Really just needs to be bolted to any solid piece of metal. Pick something that stays relatively dry, and it's best to be on the engine just to reduce potential resistance sources for grounding out your ignition system, although strictly speaking I don't see why it would be absolutely necesary.
1983 KZ750-N2 Spectre
  • MFolks
  • MFolks's Avatar
Re: Oops...
01 Aug 2012 15:34
#540018
Make sure your new location does not have any paint. Ask "Black Banshee"(Leon) about his misfortune when he went with larger battery cables.
  • Carr_113
Re: Oops...
02 Aug 2012 19:29
#540330
Thanks for the input, guys. I ended up bolting it behind the steel tab that the rear brake fluid reservoir is mounted to. I threaded a longer bolt into the tab from behind to hold the connector against the frame (which I cleaned up for a good contact), then tightened a nut down over the other side to secure it, and mounted the reservoir with a washer and another nut. Works great, and looks pretty clean, too.
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
