How do u cure a "jumpy" speedo needle?
  • 300kph
  • 300kph's Avatar Topic Author
31 Jul 2012 23:52
#539907
New cable, and the gauges have been restored by Bob at Z-Resto... The needle jumps quite a bit Lube problem? Gear drive? They say the cable should be plugged in at a 2 o-clock setting. Anyone?
Wayne
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
Re: How do u cure a "jumpy" speedo needle?
01 Aug 2012 00:11
#539909
Try this - Pull the inner cable from the sleeve; wipe it clean; put a thin coat of wheel bearing grease on in (thin coat); and reinstall. Also, make sure the speedo gear unit is installed (2 o'clock position) as stated in manual). Ed
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
01 Aug 2012 17:25
#540045
did u ask Bob about it? was it like that before the resto??
i read somewhere that there is oil inside the gauge, this acts as a damper to steady the needle. if the oil leaks out the needle will float. aparently u cannot replace it ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
The following user(s) said Thank You: BlackZ1R
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
14 Mar 2013 01:26
#576900
Hey 300kph, how did this turn out for you? Did you find a way to cure this problem? :unsure:
These gauges have dampening oil inside the drive. According to ZResto, you can't replace it. Just have to locate a suitable donor. But, if you already had them restored, you know this and that may not be the problem at all.
Did you clean and lube the cable and check your drive at the axle for proper engagement/clocking ?
Just wanting to know what you came up with.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • trianglelaguna
  • trianglelaguna's Avatar
14 Mar 2013 21:23
#576979
x2
mark1122 wrote: did u ask Bob about it? was it like that before the resto??
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • RonKZ650
  • RonKZ650's Avatar
15 Mar 2013 01:12 - 15 Mar 2013 01:17
#576988
I don't know where the oil in the gauge fable comes from, but there isn't any. They use a simple friction drive thing, don't exactly know what to call it, but the cable spins a unit in your tach or speedo, then that unit is kind of a round clutch, kind of like the old clutch on a gocart or mini bike except smaller of course. The needle is attached to the clutch, the cable spins and the faster it spins, the more this little clutch engages and moves the needle. A simple mechanical device. In my years all jumping problems have always been cable related.
Last edit: 15 Mar 2013 01:17 by RonKZ650.
  • DoubleDub
  • DoubleDub's Avatar
15 Mar 2013 01:24
#576992
From ZResto web site:
Notice the round cylinder directly atop the spring. This is the internal ?damper". If your gauge has a needle that "wanders",...at speed or RPM, and your cables are good,....this is the culprit. The damper itself holds oil, and cannot be fixed, unless this whole drive unit is replaced with one that works properly.
www.zresto.com/page2.php
  • trianglelaguna
15 Mar 2013 02:19
#576998
1976 KZ900
2003 ZX12R
2007 FZ1000
  • donthaveakawman
  • donthaveakawman's Avatar
15 Mar 2013 04:46
#577010
think with your dipstick, it needs lube
