stator pulling gone horribly awry
  • cary
  • cary's Avatar Topic Author
12 Jun 2006 10:14
#53938
in keeping with the KZ corollary to murphy's law, everything I try to do to my bike winds up taking twice as long as I had planned and being three times as expensive.
This weekend, we tried pulling off the the rotor on my '82 CSR, and wound up breaking a couple pullers, and bending up the rotor. Still didn't get it off.
Now I'll be needing another permanent magnet rotor.
Also an internal, bolt-type puller.
My question is this: will any old bolt work, or will I need to get a hardened steel specialized flywheel puller type?
I really want to avoid the hell that is a broken bolt stuck in my engine.
Post edited by: cary, at: 2006/06/12 13:30
  • cary
Re: stator pulling gone horribly awry
12 Jun 2006 10:30
#53943
I have been looking for the proper size bolt. A lot of sites sell a 18mm x 1.5-R.H.-Internal, Male flywheel puller bolt for this, however, this seems a bit too big. can anyone verify if this is the proper size?
(BTW - anyone want to sell a J-model magneto rotor or the puller bolt? U2U if so.)
  • steell
  • steell's Avatar
12 Jun 2006 14:22
#53994
Generally either the rear axle or the steering head bolt works.
How are you trying to get it off, and is it a taper fit or is it keyed? If it is keyed you should be able to see a slot in the crank and/or rotor. If it is a taper fit, screw a bolt in as tight as you can possibly get it and then give the head of the bolt a good smack with the hammer.
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
12 Jun 2006 15:26
#54004
welcome to kawasaki, i dont feel alone any more, i would break then fix. it's good ol murphys law, i feel your pain.
1979 kz 1000 06 katana 750
  • wireman
  • wireman's Avatar
12 Jun 2006 16:36
#54023
if its the same as ltd stator i might have an extra.
  • cary
22 Jun 2006 06:26
#56202
ok... got a new rotor and starter clutch... I'll be out of the country for a couple weeks for work, but when I'm back we'll be trying to extract that old rotor and get the beast back on the road
  • trippivot
  • trippivot's Avatar
22 Jun 2006 08:28
#56234
removing a rotor is an art. especially if the bike has been overheated at one time in it's life.
a bolt works fine, but it's how you do it
use metal anti seize gook on the threads
SHOCK will divide the metals on the taper friction fit
if you use a "air" impact driver dont wash out the threads. tension it up pretty good and smack the bolt with a 48oz ball peen hammer or the like but not a framing hammer they bounce . take the tension off re grease the threads and repeat.
its the shock that does the trick, not the pulling pressure of the threads.
  • trippivot
22 Jun 2006 08:39
#56242
the 2 for KZ's
16x1.5 3 inches or
18x1.5 3 inch long also
