High beam indicator flickers at 5K rpm
  • Topper
  • Topper's Avatar Topic Author
28 Jul 2012 18:05
#539246
So this just started. My high beam indicator on the dash flickers and glows dimly when I get up about 5k RPM. The high beam itself doesn't seem to engage though.
This happens even when the bike is sitting still if I rev it up to 5k rpm.
Should I be worried? and if so where should I start looking to track this down?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • MFolks
  • MFolks's Avatar
Re: High beam indicator flickers at 5K rpm
28 Jul 2012 19:08
#539255
Look inside the headlight housing for loose/rubbing wires.
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
Also, check the switch wiring in the left handlebar "Pod" for failing solder joints.
  • pete greek1
  • pete greek1's Avatar
29 Jul 2012 00:33
#539293
it could be the bulb, itself, loose connection in the headlight housing, or the wires , like MFolks said, if the wireing & connctions look OK, try switching bulbs with neutral bulb & see if it still happens..Pete
  • Topper
31 Jul 2012 12:15
#539735
Looks like this was just the bulb. This was an led style bulb I pulled it and replaced it with an old incandescent one I had laying around. No more flicker. Glad it was that easy.
1979 KZ750 Twin
