No power to anything battery has a good charge
- deers45
- KZ 900
25 Jul 2012 15:58
Me and my 17 yr. old were riding bike (76 KZ900 A4) has had no problems at all. we went about an hour and stopped for a drink came back out and nothing when the key is turned on no lights in dash or anything. i poked around and looks like all connections are hookd up and batt is good. I suck at electrical. where do i start anybody
76 KZ900 DEERS45
Re: No power to anything battery has a good charge
25 Jul 2012 16:48
Check your fuses. Ed
- RonKZ650
25 Jul 2012 17:07
Yea, look down a little ways in this forum to the "fuse gets hot and blows". This is probably your problem. The fuse burn and open at one end, so chances are at a glance it may look OK. Ignition switch is another possible. They can get corroded and melt the solder holding the wires and wires will come loose of the switch. You'll need a meter.
- pete greek1
25 Jul 2012 18:04
you can also check your ground wire from the batery to the motor, make sure the connection to the motor, is corrotion/rust free...Pete
- deers45
- KZ 900
26 Jul 2012 10:51
Thanks Guys il try that appreciate the help
76 KZ900 DEERS45
