1981 KZ650 CSR flasher relays
  • mkaplan34
  • mkaplan34's Avatar Topic Author
  • Banned
  • Banned
24 Jul 2012 19:50
#538336
Hi everyone. First time poster here. I got my KZ 650 CSR a couple of weeks ago and the turn signal relays are corroded so I am replacing them. It appears that the specs on two flashers are different. Is this the case?
I was wondering what a good replacement for the hazard relay would be? Any links would be great. The ones on the OEM parts websites that I found are between 30-45 dollars which seems crazy to me.
Is it possible to use the same ones for both flasher relays?
Thanks,
Mike
1981 KZ650 CSR
  • MFolks
  • MFolks's Avatar
Re: 1981 KZ650 CSR flasher relays
24 Jul 2012 20:17
#538343
Take your flasher relays to the nearest auto parts store, and see what they've got. They also have the electronic version, so if in the future, you use LED's, it will work, but the stock ones will not work with LED's due to lower resistances.
  • mkaplan34
  • Banned
  • Banned
24 Jul 2012 20:21
#538344
MFolks wrote: Take your flasher relays to the nearest auto parts store, and see what they've got. They also have the electronic version, so if in the future, you use LED's, it will work, but the stock ones will not work with LED's due to lower resistances.
Thanks.
I did that and they had the one to replace the turn signal relay but not the one for the hazards.
1981 KZ650 CSR
  • MFolks
  • MFolks's Avatar
24 Jul 2012 23:16
#538379
On my bike,the hazard and turn signal relays/flasher cans are the same, a 2 pin connector from the harness plugs into them.
  • mkaplan34
  • Banned
  • Banned
10 Aug 2012 22:15 - 10 Aug 2012 22:18
#541859
update:
I decided to get LED flahers and flasher relays. After some cleaning, trial and error, and yelling I decided to recheck the left hand controls.
I opened up the part and basically the wires just fell apart. Went to a salvage warehouse in the area (Baltimore Cycle Salvage) and got new hand controls for the left and right side.
now I have a high beam, low beam, blinkers, and hazards!
but...
[/ul]when I put the blinkers on and push the button to the left the left blinker blinks but the right indicator on the bar blink
[/ul]When I push the button to the right the right blinker blinks but the left indicator blinks.
[/ul]when I put the button to high beam the low beam is on, when I shift to the the low beam on the high beam comes on.
The wiring on this is very messed up. You do not even want to see the inside of the headlight. It is a work in progress haha
Thoughts?
1981 KZ650 CSR
Last edit: 10 Aug 2012 22:18 by mkaplan34.
10 Aug 2012 22:54
#541865
If needed, there's a wiring diagram in KZr's FILEBASE that may be helpful.
Attachment filebasekzr.jpg not found
Here's a direct link to the diagram:
www.kzrider.com/filebase/doc_download/308-z650h1
Good Fortune! :)
  • mkaplan34
  • Banned
  • Banned
10 Aug 2012 23:18
#541875
Patton wrote: If needed, there's a wiring diagram in KZr's FILEBASE that may be helpful.
Good Fortune! :)
Thanks Patton.
I had this diagram but this one is much clearer. With so many of the wires on the bike being cut, it is hard to figure out where they all go.
Even with the diagram.
1981 KZ650 CSR
  • MFolks
  • MFolks's Avatar
10 Aug 2012 23:36
#541880
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
