- Thank you received: 109
melted a fuses pin???
- mark1122
- Keep twisting it
Here is a pic of my melted fuse.
Attachment fuse.jpg not found
it has been suggested that the fuse holder may have had a loose connection and that it arced, and melted the fuses leg, before it blew the fuse???
I think this theory is a sound 1. any other ideas??
I have searched and found no obvious hot spots on the wires. I replaced the fuse and she runs. I have bought a new fuse receptacle to replace the old 1.
I just thought I would ask everyone’s opinion, before I go any further.
Should I bother to start cutting into the harness or just ride on.
I’m thinking I should make some changes over the winter. Maybe separate some circuits and add fuses to them, or would it be easier to start over with a 78 or newer harness that already has more fuses??
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Thank you received: 2829
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- RonKZ650
- Thank you received: 240
- mark1122
- Keep twisting it
where can i find a good suplyer for nice soft plastic wrapped bullet connectors, and fuse block and such??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Motor Head
- Thank you received: 391
Might as well do the Fuse Box conversion. Then if you decide on a new harness, you can just wire it back to the panel. Maybe make a change if you didn't like something on the 1st (Old Harness) try.
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MFolks
- Thank you received: 540
- Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- mark1122
- Keep twisting it
any more ??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Motor Head
A ground/ earth junction block, is that what you mean? so you would bring all the connections back to it, like an bus bar in a circuit panel?mark1122 wrote: thanks. i dont see any ground side blocks. any ideas where to get 1 ??
There are such Gang connectors available. But the more usual way would be to have those come to a splice, then continue to a main ground on the frame or back to Batt neg. Wire dia must of course be able to handle that. A couple of ground terminals to the frame, with splices to the individual components, is the usual set up.
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
