Bouncing Tach Needle
  • Wizzard
  • Wizzard's Avatar Topic Author
11 Jun 2006 10:32
#53674
My tack needle bounces alot what can I change in the tack to gat it to stop and does anybode have what I need? Thanks for any help!
WIZZARD!!B)
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
  • wireman
  • wireman's Avatar
Re: Bouncing Tach Needle
11 Jun 2006 10:33
#53676
try lubing cable.;)
  • Wizzard
11 Jun 2006 11:04
#53685
Whats the best thing to use to lub the tack cable with??
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
  • Wizzard
Re: ?
11 Jun 2006 11:05
#53686
Post edited by: Wizzard, at: 2006/06/11 14:06
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
  • fixer5000
  • fixer5000's Avatar
11 Jun 2006 12:24
#53695
any decent oil will do it. is your tach foam mounted? is the foam toast? if so and its mounted tight that will also cause it bounce around some. replace the foam in that case. if you at one time added washers to tighten up the mount take them outta there!!...steve
1978 kz650b pretty much stock
massachusetts
  • Pterosaur
  • Pterosaur's Avatar
Re: ?
11 Jun 2006 12:26
#53697
Practically anything, including Gris-grease:woohoo:, is better than nothing. As it stands, the cable core is beating itself against the wound metal sheath and ain;t doing any of it any good. That's where the loopy readings are coming from..
WD-40, Lock-Eze, or any of the teflon-in or graphite-in solution sprays will do.
If you really want to do the job right, pull the cable from the bike entirely, the pull the core from the sheath and soak - then flush the cable housing with mineral spirits or "Blaster", (the stuck-nut stuff) to evacuate any grunge that's built up over time. You'll be amazed.
You'll probably get a :blink: when you take a gander at the cable core as well. Rust, grunge, and sometimes, enough mud to give a geology student a woodie is caked on to it. Put it in a plastic pan with mineral spirits or Blaster overnight. Flush well in the morning.
Then, get a gob of white lithium grease in 'yer paw, and work the cable core through the grease until it's nice and gOoOpy.
Slide it back into the sheath, wipe the exterior down, and re-install...
Then, a couple of times a summer or so, pull the head of the cable from the tach and give it a liberal shot down the cable housing with your pick of sprays...
Post edited by: Pterosaur, at: 2006/06/11 15:43
  • Wizzard
Re: ?
11 Jun 2006 15:54
#53739
thanks guys I will have to check the foam and the mounts also lube the cable. thanks again.
WIZZARD!! B)
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
  • Ituen
  • Ituen's Avatar
  • Rider
21 Jun 2010 16:44
#377351
I took my KZ 750 out after work to run some errands. I noticed the tach needle bounces around while I'm accelerating. I found this thread, but can someone translate this for me?
1982 KZ750 E
Kawasaki Rider
21 Jun 2010 18:51 - 21 Jun 2010 18:58
#377407
Lube the tach cable, or replace it.
Z1 Enterprises would be a good source.
Click > Tach Cable from Z1E
And assure meter isn't hard-mounted.
The oem mounting allows cushioned movement.
Good Fortune! :)
Last edit: 21 Jun 2010 18:58 by Patton.
  • Ituen
  • Ituen's Avatar
  • Rider
23 Jun 2010 18:33
#377818
I just installed a new tach cable earlier this week. Should I disconnect it and lube both ends with WD40 before I connect it? (I just removed the old cable and replaced it with the new cable).
1982 KZ750 E
Kawasaki Rider
  • hocbj23
  • hocbj23's Avatar
24 Jun 2010 07:12
#377911
wd-40 is NOT a lubricant-it is a cleaner.I would use a lite grease like white lithium or a light oil such as 3 in 1 or sewing machine oil on a new cable.no need for the wd-40.bj
24 Jun 2010 07:45
#377918
New tach cable usually comes already lubed, and doesn't need any additional more lube before fitting it to the bike.
Should have eliminated possible cable related issue as reason for the jittery tach needle. Which leave either "mounting" or "internal" meter issue.
As earlier suggested, would assure the mounting is cushioned, so that the meter isn't hard-mounted to the bracket.
If jittery needle persists with new cable and cushioned mounting, an internal tach issue can be more problematic.
Might be dirt or insect related.
Good Fortune! :)
