This a rectifier?
  • faffi
  • faffi's Avatar Topic Author
This a rectifier?
06 Jul 2012 18:18
#534301
This is fitted to my parts bike and I suspect it's a homemade rectifier
The voltage regulator is the original part. The plan is to fit these items to my runner since it's not chargin properly. Is there a way to test and adjust the voltage regulator without the bike running, BTW?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • MFolks
  • MFolks's Avatar
Re: This a rectifier?
06 Jul 2012 18:33
#534307
Yep, it's somebody's idea of a full wave rectifier, but I see not all of the terminals are being used in the two bridge assemblies. Maybe they wanted to split the load as finding the right size was hard to do.
My understanding is the 650's had quite a variation in charging systems; for single phase,three phase, and some with relay's controlling the charging system.
Go here to look at wiring diagrams: diagrams.kz650.info/index.php
The following user(s) said Thank You: faffi
