running tail light went out need help asap
  • Dodson
  • Dodson's Avatar Topic Author
02 Jul 2012 12:01
#533325
i have a 78 kz200a yesterday i was riding at and my rectifier started smoking which it doesnt charge my battery anyways but my running tail light went out. the dual filaments are still good, the brake light works but i can now not ride it at night because i have no running light. i have read that it could be the ground wire but i dont see why it would just go out all of a sudden, i dont know if my rectifier has anything to do with it, i was hoping someone else has had this problem and would be able to give me a starting point and i can work my way through. i really like night riding but dont want the tickets. thank you in advance.
TigerKiller
  • MFolks
  • MFolks's Avatar
Re: running tail light went out need help asap
02 Jul 2012 12:33
#533342
Color Codes On Most Kawasaki’s
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
Do you have a multimeter, or can borrow one? When testing for voltage in the tail light(running light circuit) set the multimeter on VDC(Volts, Direct current, range of 20. Remove the tail light bulb & turn on the ignition switch without starting the engine. Put the RED probe inside the tail light socket, and the BLACK probe on either the battery Negative(-) terminal/post or a good frame ground.
If there is voltage, the meter will indicate it on the display, Check both of the contacts inside the socket, one will be for the brake light circuit, the other the running light circuit. if no voltage, look further back toward the wiring harness for broken wires or loose connections.
Post back your findings.
