Pitted points
- 1960vw
Pitted points
29 Jun 2012 22:02
Just trying to pick your brains as to what would cause heavy pitting on my points on my KZ305 after only 2500 miles on them. I replaced them and every thing running good now. Timing was advanced just a bit if that helps. Thanks !!!
1982 kz305
- Motor Head
Re: Pitted points
29 Jun 2012 22:08 - 29 Jun 2012 23:48
Condenser, lack of a resistor, point gap to little, dirty contacts, ie finger prints, can all lead to premature failure.
I suppose in this day of Chinese everything, poor metal quality would also be suspect.
Cleaning the contacts after setting the gap/ dwell is a Very good practice. Use a clean piece of stiff white paper, such as a new business card, away from any Ink.
Last edit: 29 Jun 2012 23:48 by Motor Head.
Re: Pitted points
29 Jun 2012 22:37
As Motor Head said, bad condenser(s) can cause this. Also, if the dwell was not set properly it may have contributed to the pitting. Ed
- bountyhunter
Re: Pitted points
29 Jun 2012 23:14 - 29 Jun 2012 23:22
redundant post.
would be helpful if the server showed the posts
Last edit: 29 Jun 2012 23:22 by bountyhunter.
