Kz305 csr
  • zno
  • zno's Avatar Topic Author
Kz305 csr
27 Jun 2012 19:12
#532169
Got the bike for 25$ on craigslist, yes 25.00$ needed carbs rebuilt, when i went and picked it up he handed me a shoe box with carb parts from 3 different bikes along with the CV32 carbs for the 305, after a week of searching for rebuild kits and cleaning the out what had been in the box i ordered the kits 64$ for both,ouch but needed to be done, started tinkering with the rest of the bike while i waited, just paint and some odds and ends, hooked up a bat to see if it would crank over and it did but i had to try out 4 diff wires i knew what one was ground obviously but there is a hot wire for electrical and one for starter solenoid, as well as some odds and ends that seem to go nowhere as well as in the headlight there are 2 wires that go do nothing no idea, havent found them on a wiring diagram and its on the stock harness, any ideas what they are for? also having a issue with starting it up the Constant vacuum carbs are pains from what ive been told but i think its a combo of spark and the carbs being way out of adjustment, can anyone tell me what i can do to stop the wires / jumper cables from getting hot and just make it reliable to crank it over without catching on fire?
  • faffi
  • faffi's Avatar
Re: Kz305 csr
28 Jun 2012 03:03
#532296
Have you tried to raise your question here www.armbell.com/kz400/index.php?mforum=kz400 ?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
