Dyna 3.0 ohm or 2.2 ohm to match the dwell
23 Jun 2012 10:23 - 23 Feb 2013 16:06
1981 KZ650-H1 CSR w stock electronic ignition.
What aftermarket coils can I use w the stock electronic ignition?
The only thing I want to swap out is the coils.
Direct bolt-on would be preferable.
I looked around Z1Enterprises.com & the KZ650.Info site but wasn't sure. Thanks.
Last edit: 23 Feb 2013 16:06 by martin_csr.
Re: Coils for 81 650-CSR w Stock Elec Ignition?
23 Jun 2012 11:55 - 23 Jun 2012 12:06martin_csr wrote: 1981 KZ650-H1 CSR w stock electronic ignition.
PS: I forgot to add that coils that will work w a Dyna-S or something for future change to aftermarket ignition system would be good, in case my igniter gets fried or something.
The green Dyna 3 ohm coils should work okay with the stock electronic ignition (although the stock coils are slightly less than 3 ohm), and would also match a later installed Dyna-S.
The green Dyna coils are bolt on when fitted to Z1 and KZ900 (and likely other large Kaw fours), but am uncertain about ease of fitment on KZ650.
www.z1enterprises.com/detail.aspx?ID=210
When installing the Dyna coils, the Dyna folks recommend mounting the coil with the spark plug wires routed up and forward away from the coil, and then looped down and back to the respective spark plugs.
For whatever reasons, some few installers elect to mount Dyna coils in the opposite direction with the plug wires routed down and toward the back.
Last edit: 23 Jun 2012 12:06 by Patton.
Re: Dyna 3.0 ohm or 2.2 ohm to match the dwell
23 Jun 2012 13:48 - 22 Feb 2013 18:30
Thanks. Z
Last edit: 22 Feb 2013 18:30 by martin_csr.
- loudhvx
23 Jun 2012 14:17
3 ohm coils should work, but the gray 2.2 ohm coils are a better match for the dwell on the stock system.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
