Speedo not working
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
Speedo not working
23 Jun 2012 01:38 - 23 Jun 2012 01:38
#531160
The speedometer on my dad's 81' KZ1000LTD quit working. No gauge, oil light, or neutral light but the left turn signal indicator in the gauge still worked. We traced the common wire for the lights and speedo into the harness (brown wire) and found that it was severed inside the actual harness. We fixed that wire and now the oil and neutral lights work as they should but still no speedometer. The wires coming from the sender on the wheel are (black w/ yellow stripe, blue w/ white stripe, and white) all from a 3 pin connector. What do these wires do? Also the wires coming from the gauge are (Turquoise, Green, red w/ blue stripe, Black w/ yellow stipe, brown, blue w/ pink stripe, and an orange wire) all from a 6 pin connector except for the orange wire. We do have a wiring diagram but it does not state what each wire does. Was wondering if anybody could tell me what these wires do coming from the sender and going into the gauge.
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 23 Jun 2012 01:38 by Kitten Tooth.
