timing a dyna s???
  • Tomolu5
  • Tomolu5's Avatar Topic Author
timing a dyna s???
23 Jun 2012 00:09
#531138
The instructions that came with my dyna unit were crap, just trying to cover all bases and make sure shes right. are there any special requirements/tips to time these things, I just used a clamp on timing light, and set it to the stock marks at idle, did 1&4, and checked 2&3.
76 kz900
dyna s
green dyna coils
stock plugs gapped at .039
Thanks
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: timing a dyna s???
23 Jun 2012 00:17 - 23 Jun 2012 00:17
#531142
Here you go...
Dyna S Coil
Dyna S EI Installation
Attachment DynaSBenchTest.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 23 Jun 2012 00:17 by Old Man Rock.
The following user(s) said Thank You: Tomolu5
  • Tomolu5
26 Jul 2012 22:56 - 26 Jul 2012 22:57
#538883
what do you mean by "this time use the T mark..." in the last step? reason I ask, is when I time my bike with a light, it seems to run alot, lot better when timed to the T mark(with a light). but...I do run out of room on the plate, same as you did when shooting for the F mark(same advancer). My intent is to follow the static timming directions to a tee this weekend, replace jets with new(re-re-reclean carbs), and see where we are at. I just havent had the time to sit down with her :blush:
Mine:
Last edit: 26 Jul 2012 22:57 by Tomolu5. Reason: typo
