On/Off toggle switch in place of clutch switch?
- gwolever
20 Jun 2012 23:32
Hey guys.
I recently posted about a problem I have with my new clutch lever not fitting up against my left hand control unit because the clutch switch on my new lever is in the way.
A suggestion by wireman was to bypass the clutch switch with a toggle switch under the tank. I like this idea.
Has anybody ever done this?
Any suggestions?
Just wire the 2 black wires normally going to my clutch switch to an on/off toggle switch should work, shouldn't it?
10 amp toggle switch? or 30 amp switch?
Thanks.
Attachment 004_2012-06-20.JPG not found
Any suggestions?
Thanks.
1982 KZ1000 CSR
- MFolks
Re: On/Off toggle switch in place of clutch switch?
20 Jun 2012 23:55
Where would you mount it? I'd think a spring loaded one to the off position would work better, so you'd need both hands to start the engine.
Here's some Mil-Spec toggle switches:
MS24523-22 SPST Toggle Switch
www.alliedelec.com/search/productdetail.aspx?SKU=6422180
MS24523-23 SPDT Toggle Switch
www.bpbsurplus.com/lc/cart.php?target=pr...7468&category_id=325
MS24523-28 SPST Toggle Switch Momentary
www.bpbsurplus.com/lc/cart.php?target=pr...8139&category_id=325
MS24524-22 DPST Toggle Switch
www.prowireusa.com/prodinfo.asp?number=MS24524-22
SPST = Single Pole,Single Throw.
SPDT = Single Pole, Double throw.
SPST = Single Pole, Single Throw Momentary (a spring loaded switch to the off position).
DPST = Double Pole, Single throw.
Some other websites for commercial grade switches:
www.waytekwire.com
www.delcity.net
Try to get a toggle switch rated for moisture resistance. Most marine(boating) switches are.
www.waytekwire.com
www.delcity.net
- MFolks
21 Jun 2012 00:00
The Mil-Spec toggle switches I listed, take the #6 ring terminals.
Wire Termination Insulation & Sizes
Terminal Insulation Color Wire Sizes
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
RED
8 Gauge
BLUE
6 Gauge
YELLOW
4 Gauge
The ring terminal holes comes in many sizes, from #4 up to 1/2" in most cases, it's a matter of finding the tightest fitting hole to fit the fastener for the termination.
American Wire Gauge(AWG) is backwards to what many people think; that is 22 gauge is many times smaller than 10 gauge even though the number is bigger.
www.pbase.com/mainecruising/wire_termination
(The Good, Bad, & Ugly Wire Crimpers)
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
RED
8 Gauge
BLUE
6 Gauge
YELLOW
4 Gauge
- wireman
21 Jun 2012 02:01
check your pm box
- Kitten Tooth
23 Jun 2012 04:38
DUCT TAPE, LOTS AND LOTS OF DUCT TAPE!!
i just jumped the two wires for the clutch lever coming out of the harness. The lever is like a momentary push button switch like you would use for a starter. I'd listen to wireman though. Going my way might lead to trying to start the bike while its in gear causing it to jump forward off of its kickstand..
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Old Man Rock
23 Jun 2012 09:34
I get the reasoning kawi designed it this way but since I don't drink & drive so...
For me.... Jump the damn thing where no switch is needed at all...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
23 Jun 2012 10:01
Back in the day when I was still riding my BSA a guy was showing me his brand new 1976 Yamaha XS750 triple - bragging about its virtues. The bike was sitting on its side stand. He looked at my old BSA and proclaimed "No more kick starting for me; this baby has electric start!" And with that he pushed the starter button. When he did the Yamaha lurched forward off the side stand and crunched down into the gravel screwing up the paint job on his tank. He had left it in gear when he parked it, and it was not equipped with a starter lock out switch. I kick started my BSA and rode off vowing I would never buy a bike with an electric starter. :laugh: When I broke my vow a year later I was glad to learn about the lock out feature. Neither of us had been drinking.
- Old Man Rock
23 Jun 2012 10:08
Yeah but your old and retarded Ed...
:laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
