KZ305 coil wiring
- 1960vw
KZ305 coil wiring
19 Jun 2012 00:47
Ok,I disconnected the coil wires to test coils. Coils good. I replaced wiring in what I thought was the correct way. Now no spark
I've got the yellow/red wire hooked to the double connector red/yellow, which makes sense. Now there is a black wire from the right side coil and a blue and a yellow wire from the condensor. They go to where? There is a double connector end on two wires going to a single end coming from points. Left coil has a yellow wire with an open double end. Which one goes to that single end? :blink:
1982 kz305
- Motor Head
Re: KZ305 coil wiring
19 Jun 2012 22:18
I see this post for a diagram, if that helps.
Your Points would have both the condenser wire and the wire going to the neg of the ignition coil.
- 1960vw
20 Jun 2012 01:16
Thanks, found the diagram.
Had to blow it up for my old eyes but found the correct hook up. Got spark now to both plugs.
Pulled them to verify. Now Just have to get fuel hose to replace the old one. Hopefully in a couple of days I can get it all together and give it a try to start. Thanks again!
1982 kz305
