How to connect new LED flashers?
  • gwolever
  • gwolever's Avatar Topic Author
18 Jun 2012 21:58
#530216
Hey guys.
I just bought a couple new LED flashers to replace my stock flashers as I am using LED front and rear blinkers. The flashers are 2 prong and indicate which prong is Load and which is Battery.
www.cwswiring.com/Shop.html
My problem is figuring out which wires from stock setup are which.
I'm not sure what kind of problems I might run into if I wire them backwards, but I'd like to avoid that anyway.
On one stock flasher, I had an orange wire to one prong and a red/green stripe wire to the other.
Attachment 011.JPG not found
On the other stock flasher, I had 2 orange wires hooked up to the prongs.
Attachment 013_2012-06-18.JPG not found
I can't read wiring diagrams very well, so any help would be greatly appreciated if you guys have any ideas.
Thanks.
1982 KZ1000 CSR
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: How to connect new LED flashers?
18 Jun 2012 22:10 - 18 Jun 2012 22:11
#530218
I dont think it matters. just switched my wires and they worked the same both ways. the forum will correct me if not correct. I didnt buy a new flasher as mine work ok but blink a bit slow but ok I think
Last edit: 18 Jun 2012 22:11 by 4TheKZ1000. Reason: info
  • Weiss Tiger
  • Weiss Tiger's Avatar
18 Jun 2012 23:26
#530239
Do you have a test light? If you do take the test light and touch the inside of 1 of the terminals and see which has power with the key on. The other wire should have no power. You might have to turn your signal light on for it to have power going to it.
Best of luck B)
1983 KZ550 M1 LTD Shaft
Teikei 26 CV carbs
No Mods
  • BikeDude2002
  • BikeDude2002's Avatar
  • Today is a good day to ride...
19 Jun 2012 00:06
#530246
With regard to the flasher hookup, if you install them and they do not flash, just reverse the leads. The flashers will be fine. The installation instructions sent with the unit (in the email confirmation sent to you) should cover this. Sorry these directions might seem a bit crude, but due to the number of different motorcycle these units are compatible with, there is no way to cover every iteration. If fact, on my KZ650, the leads that go to one of my flashers are both orange w/green stripe! :woohoo:
BikeDude2002
(Dan)
78 KZ650 SR
90 Yamaha Radian
  • gwolever
19 Jun 2012 00:48
#530259
Cool. Thanks for the input guys.
1982 KZ1000 CSR
  • 4TheKZ1000
19 Jun 2012 16:30
#530357
if you got the flasher from creative wiring solutions it tell you which is the load on the side of the flasher? it also says non load sensitive on flasher
  • ironleg
  • ironleg's Avatar
  • its not what you ride its why
19 Jun 2012 23:45
#530441
wow thats great i was just geting ready to ask if ther was a better way than a resistor in line with the led turn signals !!! thats great thanks
78 1000 ltd current project
75 z1 900 Dragbike 78 frame GS 1100 swing arm yamaha rear wheel dyna-s dyna 2 step best time 12.02 1.59 60ft
71 harley shovelhead chopper
2002 harley springer softail
1999 yamaha 600 grizzly
