Main Harness Question
- 4TheKZ1000
14 Jun 2012 15:45
I have a question about two wires from the main harness that goin into my headlight . Inside the headlight Im having trouble with the following 2 wires.
Thanks, Spencer
- Single brown wire with a female end
- A brown and white wire with a double female end
Thanks, Spencer
- 4TheKZ1000
Re: Main Harness Question
16 Jun 2012 12:43
the brown with white strip is 12v with ign key on. the brown wire is the same? must be for accessories of some kind.
- T_Dub
16 Jun 2012 15:38
Must be, could also be for different models, maybe Kawi used the same harness for multiple bikes. I spot no less than 3 power taps and 2 blinker taps on that wiring diagram with no mention of what they're for.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- MFolks
16 Jun 2012 16:06
Some power connections may be for a heated vest or grips(usually with seperate fuses). The Brown wire may be switched, making it useful for a relay circuit you know will be off, when the ignition is off.
