Questions on Dyna grey coils on 80 KZ1000
- mtkawboy
12 Jun 2012 20:06
Im putting a set of grey Dyna coils on my 80 KZ1000 with factory electronic ignition. Do I hook them up direct or is there a resistor I have to remove / If there is a resistor is it built into the wire or seperate ?
- MFolks
Re: Questions on Dyna grey coils on 80 KZ1000
12 Jun 2012 22:21
Do you have a wiring diagram? It should show a "Ballast Resistor" if your bike has one. I'd lift the tank, looking for a resistor wired into the ignition coil circuit.
The "Filebase" here might have a diagram, it's located in the upper right hand of this website's home page.
- mtkawboy
12 Jun 2012 23:04
Nothing there but an original ad
- Motor Head
12 Jun 2012 23:06
The Factory Electronic Ignition had no Ballast Resistor, the points systems did though.
- pete greek1
12 Jun 2012 23:09
all the way to the top, where you click on forom....allthe way to the right. it should say file base
The following user(s) said Thank You: mtkawboy
- mtkawboy
13 Jun 2012 00:38 - 13 Jun 2012 00:39
I was in the file base, theres nothing there but an original ad under the 1980s. Thanks for the help Motorhead
Last edit: 13 Jun 2012 00:39 by mtkawboy. Reason: spelling
13 Jun 2012 00:48Attachment filebasekzr.jpg not found
