1 and 4 cold
- 5150BOT
- Lithographer,A&P Mechanic
1 and 4 cold
10 Jun 2012 17:08
Hey Gents got everything back together took it for a test spin and it seemed as it warmed up it started running crappy to the point that I thought it was gonna croke.. Ok when I got the bike it seemed to run ok except when you got on it... it seemed to sputter and cut out I figured carbs whatever,,, but now
Im all confused about :S is 1st off the primary wires going to the coils I have a clymers manual showing me at the coils its blue yellow black and red, but at my coils I have red and black for left side and red and green for the right side this is the way I mark it before I took it apart
2nd is would half a coil die out allowing 1 and 4 to be cold?
1981 KZ1000K1 LTD
- baldy110
Re: 1 and 4 cold
10 Jun 2012 17:13
The two coils fire 1&4 and 2&3. If 1&4 are not firing then that coil is not working, no such thing as half a coil.
- 5150BOT
Re: 1 and 4 cold
10 Jun 2012 17:55
I cant believe it was that obvious :laugh: haha guess thats what I get for being a aircooled VW mechanic for 30 plus years,, I was thinking 1-3 2-4 thanks for making see that infact 1&4 is the left coil and 2&4 is the right coil,, well Im getting closer any suggestions on coils best product best price combo/igniton kit.. just sunday driver so I dont need a fire breating-- cinder farting coil. just something simple n cheap Thanks Mike
1981 KZ1000K1 LTD
- ramtough_63
Re: 1 and 4 cold
10 Jun 2012 18:07
you can generally pick up a decent set of dyna coils on ebay 80-125.00 bucks with that said 150.00 will get a new set 40-60 for a stock set used of course. put up a wanted post and see what happens brian normally has about anything you need lol used
Dyna seems to be what most use price and quality Z1 enterprise has about anything you need
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Re: 1 and 4 cold
10 Jun 2012 18:10
Do all VW's use the same coil.
- 5150BOT
Re: 1 and 4 cold
11 Jun 2012 14:33650ed wrote: Do all VW's use the same coil.
@650ed not sure of your question but yes all aircooled vw's use the same stock coil and there is only one coil per engine
Attachment beets.jpg not found
Attachment coil2.jpg not found
@Ramtough_63 -- Thanks Im going to head to the kaw dealer and see what they got and prices then compare it to online plus shipping,, I just hate to wait lol Thanx guys
1981 KZ1000K1 LTD
Re: 1 and 4 cold
11 Jun 2012 18:08
I asked because the same is not true for all KZ 4 cylinder engines. For example a KZ400-J 4 cylinder KZ is considerably different than a KZ1100. So, in order for folks to make a good recommendation they would need to know what year/model motorcycle you are trying to fix. You may want to add the info to your signature. ed
- 5150BOT
Re: 1 and 4 cold
14 Jun 2012 03:10
Figured I would post what the problem was first off I had a faulty multimeter which didnt help I swapped coils the problem followed that coil so it seemed like bad coil right? waiting for coils to arrive got a new meter thought I would play with it a bit grabbed the number 4 plug wire because it was the first thing and closest thing I looked at checked it, I didnt have any continuity I was like wth! touched probes worked tried wire didnt work I shoulda got a fluke the first time :whistle: So what was wrong was the 2 plug wires 1&4 were bad almost 2 inches in at the coil side I sliced parallel into em until I found good clean wire.
Thru on some old wires fom my rail and bingo so I ordered some from Z1
Anyone got some good valve setting advice/procedure Thanks again guys I will get some pictures soon in the process of moving so everythings a cluster atm
Mike
Mike
1981 KZ1000K1 LTD
