complete electric shutdown- ?????
  • kfs
  • kfs's Avatar Topic Author
09 Jun 2012 18:23
#527846
Was out for a ride today; pulled up to a light and all the electrics went dead. Checked all the fuses all appeared to be good. Had to hitch-hike home to get the car and trailer. Got the bike home;checked the fuses with an ohm meter; all good. I have power to the main fuse. But no power from there on. Any thoughts or suggestions would really be appreciated? Thx in advance.
  • rstnick
  • rstnick's Avatar
Re: complete electric shutdown- ?????
09 Jun 2012 20:33 - 09 Jun 2012 20:34
#527864
I had a similar problem with my KZ.
While on a ride, all power went out 4 or 5 different times.
Lights and engine dead.
But I was lucky that a few seconds later, all came back on, and she started each time.
Once I had the time to check her out, I cleaned the main power wire, the white one running to the 20 amp fuse. Checked and cleaned each connector on the white wires run.
I also cleaned the ignition switche's 6 prong plug with contact cleaner, and carry a spare igition switch just in case.
In the few weeks since I had that problem, she has not had the power failure again.
Hopefully I've found and corrected the problem.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 09 Jun 2012 20:34 by rstnick.
  • Grantl
  • Grantl's Avatar
  • KZRider is Da Bomb!!!
16 Jun 2012 14:59
#529604
I have a KZ1000p and have been having intermittant power failures. Mostly the bike just shuts-off--just like shutting off the ignition switch. At the moment, I can get power to the ignition switch, but the starter button does not spin the motor when pressed. I suspect broken wires or broken connectors or maybe a bad fuse box--I just don't know enough about electrical to be confident that I can track down the source of this problem.
This bike has had most of the police gear removed, and the previous owner has done some re-wiring--not so well done.
My question, how do you bypass the starter lockout switches (one on the kickstand, and one at the clutch lever?)
Question 2: Can I check the starter relay by measuring current going to the starter motor--when I depress the starter button? I have tried jumping the contacts on the starter relay... This freaks me out to do this. When I tried it, I got lots of sparks, but the starter motor did not spin.
Could I have a bad starter relay?
Any help you could provide will be appreciated.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
  • kfs
23 Jun 2012 13:13
#531242
Turns out the problem was the fuse box. It looked clean and corrosion free, clips were snug. But alittle contact cleaner and a Q-tip solved the problem. Amazing it looked clean.
