dyna coils
- 550ltdkeith
09 Jun 2012 14:33 #527831
by 550ltdkeith
dyna coils was created by 550ltdkeith
I have a 81 550 ltd with stock wires and coils. I have been considering some dyna coils and wires and some e3 plugs or something along those lines. Maybe a plug with a larger gap. I don't know what coil to get or if I can make the gap bigger for more spark.engine has some mods like pods and a mac 4 to 1 header that is wrapped, and a dyno jet rejet with a 108 main and a 37 pilot jet.
- loudhvx
- Thank you received: 1616
09 Jun 2012 20:23 #527861
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic dyna coils
If it's the stock electronic ignition system, (which is probably the best option if keeping the mechanical advance), then you want Dyna grey 2.2-ohm coils. You can go a tiny bit bigger on the gap maybe like .030" (versus stock .026") and be ok with the coils. If the igniter pops, you can make the HEI one for dirt cheap.
1981 KZ550 D1 gpz.
Other links.
- 550ltdkeith
10 Jun 2012 01:34 #527903
by 550ltdkeith
Replied by 550ltdkeith on topic dyna coils
I am getting a acewell speedo/tach and the tach lead goes off the plug wire. I know I can get the copper plug wire or the graphite one that does not flow as well. I just don't want to.mess up the speedo or tach with to much magnetic interference.
