LED tail light question
  • joshjones84
  • joshjones84's Avatar Topic Author
03 Jun 2012 20:19 - 03 Jun 2012 20:19
#526641
im going to buy a cheep LED tail light off ebay to replace that brick i have on the back. can i just connect the wires and hope it all works out? what will i have to do to make it work?
82 KZ550 LTD
Last edit: 03 Jun 2012 20:19 by joshjones84.
  • ramtough_63
  • ramtough_63's Avatar
Re: LED tail light question
03 Jun 2012 20:32
#526646
my first one worked like a charm only problem i had was the brake warning light sensor flashed all the time ubhooked it worked great. had a mishap recently and tore it up so i ordered another one (different style this time)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • D.Nel928
  • D.Nel928's Avatar
03 Jun 2012 21:55
#526656
Both of mine have worked just fine. No failure light either, just plug it up and go.
'78 KZ650 Custom thingy turned turbo build
www.kzrider.com/forum/11-projects/520339...z650-fighter-project
  • LarryWaverly
  • LarryWaverly's Avatar
07 Jun 2012 01:04 - 07 Jun 2012 01:04
#527374
Test your LED light when connected to something other than your truck - see if if works, it should isolate the problem. Most likely the LED strip does work, in that case definitely check your circuits - whether everything is connected and if one of them is fried.
LED Downlights spotlight lighting LED Bulbs Wholesale
Last edit: 07 Jun 2012 01:04 by LarryWaverly.
