1982 speedometer gauge
- daveo
02 Jun 2012 20:12
Is there a calibration adjustment on the electric speedo? I mounted a GPS on my bars, and discovered my speed above 65mph doesn't read correctly. I'm actually cruising at 73 when my gauge shows 65, and it gets worse the faster I go.
1982 KZ1100-A2/1170 sleeper 😀
- MFolks
Re: 1982 speedometer gauge
02 Jun 2012 22:20
Did you change fron tire size(bigger/smaller)?
- daveo
08 Jun 2012 12:34
Size as specified, with minimal tread wear.
Thanks...
Thanks...
08 Jun 2012 15:12
hmmm, interesting. Usually they are off in the other direction, that is, speedo usually reads 5-10% faster than actual speed, I'll bet a speedo shop could recalibrate or repair it, but may be $$$$$.
