Tach problems
- vondikka
Tach problems
30 May 2012 18:16
78 kz650 c2 bike revs up normally but the tachometer wont read past 3500rpm. im assuming its getting stuck or something. You guys got any advice ?
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- MFolks
Re: Tach problems
30 May 2012 18:49
Cable operated Tach? I'd remove the cable from the engine and then pull the inner cable out,clean it & inspect for broken cable strands and re-lube it, installing it back on the engine.
Got a cordless drill? Connect one end to the tach cable and the other to the drill and see if the problem is the cable or tach.
- JR
Re: Tach problems
30 May 2012 23:45
Best do what mfolks said first
I had a piece of one of the bulb holders come loose inside and jam the tach. I took the tach off. I cut the ring which keeps both halves together. I took the 2 halves of the tach apart and fixed the problem. I put the ring back in place using epoxy putty as glue and clamped everything until it set. I kept the gap in the ring facing inward so not noticeable.
I think Z1 Enterprises outsource tach restoration. You migh want to contact them either and check that option.
