Couple wiring questions...
- kz750bobberz
30 May 2012 17:27
I am new to the forum and i just had a few questions that someone probably could answer fairly quickly. First question is off my ignition switch i have a brown and a white wire does anyone know what these would have gone to originally? Second is kind of electrical kinda brake related. i ordered a rear brake universal switch for the bike of z1 enterprises however the spring it comes with is to strong(keeping the brake light on always) so i tried to use the old spring but its weak and doesnt return the pedal anyone know of any suggested fixes?
I aprecciate the help guys.
- MFolks
Re: Couple wiring questions...
30 May 2012 17:39
Try this website for several years of wiring diagrms:
kz.bike-night.com/manual.html
As for the spring, if you've got a local hardware store, they usually carry a selection of tension and compression springs. Tension means stretches,compression will be squeezing.
- ginarose12
31 May 2012 17:29
I'm not sure about the wiring, but this site has a lot of springs that would probably help you out!
stanleyspring.com/
- 4TheKZ1000
31 May 2012 21:07
the white comes from the ign switch and runs back to the fuse block. there are 3 to 4 brown wires. one is left alone and the others connect on basis of hand control type and model.
