kz650 to kz750 electrical help
  • carolinaboy
  • carolinaboy's Avatar Topic Author
30 May 2012 13:16
#525869
I bought a project a while back. It came with a kz650b1 frame and a kz750e engine.
I began putting on the wiring harness, which is probably from the kz650, and began to see some differences. What do I need to make this engine swap work? A complete kz750 harness? Are any parts shared? Since the engine is the only thing from the kz750, I'm assuming ignition and charging would change. I didn't notice a difference until I went to hook up the ignition points and noticed there were too many wires.
Can anyone offer their expertise on this?
  • carolinaboy
Re: kz650 to kz750 electrical help
30 May 2012 13:23 - 30 May 2012 13:24
#525872
I should add that it came with MOST of a kz650b disassembled. The powerplant alone was from a kz750e.
The regulator it came with is a combined reg/rec unit.
Last edit: 30 May 2012 13:24 by carolinaboy.
