brake warning light stays on
- riverroad
- 1980 1000LTD B4
29 May 2012 14:07 - 29 May 2012 14:08
Hi all, again, I haven't been on here for a long time. Just proves how dependable the old girl is.
This time it's just a minor annoyance.
Can't figure out why my brake light stays on. My brake light in back works fine with either the front or back brake actuated, but the light on the dash won't go out when I let go of the brakes.
Can anybody tell me where to look?
1980 KZ1000LTD B4.
1980 KZ1000LTD B4.
Last edit: 29 May 2012 14:08 by riverroad.
Re: brake warning light stays on
29 May 2012 15:01 - 29 May 2012 15:06Does the dash light stay off at first (normal), then light up when either brake is applied (normal), but remains on thereafter even when all braking is released (abnormal)?riverroad wrote: ...brake light stays on. My brake light in back works fine with either the front or back brake actuated, but the light on the dash won't go out when I let go of the brakes.
1980 KZ1000LTD B4.
In any event, would check for loose or corroded connection at the brake light failure indicator switch.
Last edit: 29 May 2012 15:06 by Patton.
- riverroad
- 1980 1000LTD B4
30 May 2012 08:16Patton wrote:Does the dash light stay off at first (normal), then light up when either brake is applied (normal), but remains on thereafter even when all braking is released (abnormal)?riverroad wrote: ...brake light stays on. My brake light in back works fine with either the front or back brake actuated, but the light on the dash won't go out when I let go of the brakes.
1980 KZ1000LTD B4.
I washed the bike about a month ago, and the light has stayed on ever since. It only turns off when I turn the bike off. Otherwise it's always on.
I saw that brake light failure indicator switch on my Clymers wiring diagram, but can't locate it on the bike. Know where it is? And thanks Patton!
- JEFFG1
30 May 2012 09:10
you mite want to check the switch on the frame behind the pedel it has a little spring on it you mite have bent it alittle when you washed it if that is the case you mite have to readjust it .
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
30 May 2012 12:05JEFFG1 wrote: you mite want to check the switch on the frame behind the pedel it has a little spring on it you mite have bent it alittle when you washed it if that is the case you mite have to readjust it .
Yes, and the rear brake switch or the front brake switch isn't disconnecting when brakes aren't being applied. Perhaps moisture inside the rear switch is preventing it from disconnecting when released. Or maybe the adjustment is set too tight, and could be readjusted to require further pedal motion before it connects inside. May use finger to assist closure of the rear switch to see whether the brake light goes off.
The front brake switch is a pressure switch activated from increased pressure in the brake hose while the front brake is being applied. Possibly the switch has gone bad, and is always connected, even without any pressure. Could remove one of the wires connected to the switch, and see whether the brake light goes off.
The Brake Light Failure Indicator Switch is probably located underneath the fuel tank.
May have three wires (perhaps yellow; black; green/white) connected into the main wiring harness via a 3 piece connector.
- Topper
30 May 2012 13:33 - 30 May 2012 13:34
Just to be sure I understand, the brake light itself functions properly right? It's just your dash indicator that's the issue?
If I've got that right, it isn't the rear pedal switch or the front pressure switch.
Fault indicator under the tank sounds like the culprit. Or pull the dash bulb and see if something has shorted there.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
Last edit: 30 May 2012 13:34 by Topper.
- riverroad
- 1980 1000LTD B4
30 May 2012 14:16
That would be correct Topper, the rear switch and the front pressure switch both function properly. The rear brake light on the rear fender illuminates when either the front brake or rear brakes are applied, and turns off when I let go of the brakes. It's just the dash brake warning light that constantly stays on.
So, it has to be a dash light problem, or that fault indicator thingy that's causing it. But I do specifically remember it came on and stayed on right after I washed it. I may have hit the dash too hard with the spray wand and got water inside the dash assembly, but since it happened over a month ago, I would've thought any moisture would have dried out by now. Of course, it could be corroded under there too. So I'll take my dash apart next chance I get.
- Topper
30 May 2012 16:22
Sounds like a plan. Recently I've noticed my neutral indicator light glows faintly when the bike is wet. I haven't tried to track it down yet, but I'm guessing there's a short somewhere in that line.
1979 KZ750 Twin
1979 KZ750 Twin
- toadson
02 Jun 2012 01:31
Hey Don, haven't talked to you in years. I've still got my KZ as well, we need to ride sometime! I have the opposite problem of you.... my brake light indicator quit working. I think its a bad bulb socket, but have been too lazy to deal with it. I know its off topic but haven't seen you on here in quite a while.
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread:
kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
- riverroad
- 1980 1000LTD B4
05 Jun 2012 13:25
Hey Todd. Sure has been a long time! You still livin in Jerseyville?
I don't work at Boeing anymore. Took a job as a Plant Manager in an explosives plant. I try to manage through binoculars now LOL!
Still haven't gotten around to fixing my lit up brake indicator. Just like you I'm too damned lazy or busy to mess with it.
I was going to ride with Jeff and Steve over the Memorial day, but my sister in law from Chicago showed up with her new husband. I never even got a cgance to call them guys and tell them I was busy.
Yeah I wouldn't mind going for a ride sometime. Just don't know when.
