turn signals
  • kawman66
  • kawman66's Avatar Topic Author
turn signals
27 May 2012 21:46
#525271
Ok guys i need help I've got my wiring almost done but i have a few issues. I bought all new harnesses and hand controls.I figure plug and play right well wrong here's the issues first off i have switched to led front and rear turns and tail light bought the no load flasher installed led in the turn indicator on the dash. Well first off when i turn on the turn on right or left all 4 are blinking, till i take out the turn indicator bulb then they work correctly till i start the motor then they come on on each side seperatly but are solid not blinking turn off motor works fine. so i have tried unhooking the alt thinking i was get a back feed but same condition unhooked power to flasher and powered seperately with my power probe same thing what the heck can it be. if i leave unhooked they dont work so it dont seam like a its got a short. thanks for any help.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
  • kawman66
Re: turn signals
28 May 2012 14:44
#525382
well figured it out the new no load flasher was bad installed a ep 35 and fixed
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
