Coil wiring?
  • Tomfox
  • Tomfox's Avatar Topic Author
Coil wiring?
25 May 2012 23:33
#524842
I need to know what color wires go to which ccil and which color goes to which terminal.... Thank you
  • Tomfox
Re: Coil wiring?
25 May 2012 23:43
#524844
Guess I should tell you what kind of bike, that might be helpful. Its a 1982 KZ650 CSR.
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
Re: Coil wiring?
26 May 2012 00:01
#524853
  • Tomfox
Re: Coil wiring?
26 May 2012 00:30
#524862
Thanks, that helps a lot. I've got one more Question for you. How do I know which coil is which? it does say RH or LH. And what side is the #1 cylinder on?
  • MFolks
  • MFolks's Avatar
Re: Coil wiring?
26 May 2012 00:55
#524867
As you sit on the seat, #1 will be on the far left, with the other cylinders left to right. The same for the ignition coils.
  • Tomfox
Re: Coil wiring?
26 May 2012 01:02
#524868
I got it all figured out. Thanks again!
