wiring issue?? 1982 LTD 440
- geilfuss
25 May 2012 17:02
I have a 1982 LTD 440, I have some sort of wiring issue. One day i will have power to everything then 30 minutes later i can't get power to anything. This is my first bike i have only had it for a few months. Any body have any suggestions. I tested the battery, and its not that. The battery is good.
- osage
Re: wiring issue?? 1982 LTD 440
25 May 2012 18:29 - 25 May 2012 18:33
How is your main fuse? I have had my fuse holder lose it's grip on the fuse. power would come and go as contact was lost or made.
Also do a search here for electrical trouble shooting info that Mfolks posts. I have used it to correct some problems on my bikes.
Try this post
www.kzrider.com/forum/2-engine/523970-af...-ritual-of-fi#524087
Try this post
1976 KZ750B1
1982 KZ750H3
1982 KZ750H3
Last edit: 25 May 2012 18:33 by osage. Reason: add a link
- 4TheKZ1000
25 May 2012 18:41
do what I did, spend the $140 and get a new harness and have no more problems. best money I spent
- osage
25 May 2012 18:47
Where's the fun in that
everybody should spend time working in the headlight bucket :woohoo:
1976 KZ750B1
1982 KZ750H3
1982 KZ750H3
- MtStateMike
25 May 2012 19:20
Few weeks ago I lost power to everything on my KZ1000. I found that my harness connector were melted together under the tank, my main 30amp fuse was blown and the screw for the main power out of the battery was loose. Tightened the screw, still nothing, replaced the fuse - nothing. I didn't want to buy a harness because my bike is a KZ1000p that I didn't want to look like a police bike. So I cut out the entire wiring harness and began from scratch. Rewired the entire bike and it runs better than before, more power like maybe one of the wire from one of the coils wasn't flowing to the ignitor or something. Can't explain it, but it runs better. If you don't have to rewire for a reason like I had. I would recommend either getting a harness or someone who has any idea of what to look for to take a look. Best of luck.
92 KZ1000p
Lumberport, WV
Lumberport, WV
25 May 2012 21:56 - 25 May 2012 22:03Would assure integrity of the ground connection where the negative battery cable attaches to rear of the engine.geilfuss wrote: I have a 1982 LTD 440, I have some sort of wiring issue. One day i will have power to everything then 30 minutes later i can't get power to anything. This is my first bike i have only had it for a few months. Any body have any suggestions. I tested the battery, and its not that. The battery is good.
Might also be corrosion inside the Kill switch or inside the Ignition switch.
Would also check for corrosion of clips on wiring to/from the main fuse.
May find a wiring diagram, service manual, or other help at:
www.armbell.com/forum/index.php?c=6&sid=...571a51a&mforum=kz400
www.kz400.com/
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
Last edit: 25 May 2012 22:03 by Patton.
