Brake light indicator
  • kc5deb
  • kc5deb's Avatar Topic Author
05 Jun 2006 22:28
#52450
Once again, as I tie into my new old KZ650, I'm discovering things that I have not the knowledge for.
Upon replacing all the bulbs under the indicators, I noticed that the brake light never comes on; neither with the front or rear brake initiated.
When looking at things further, I noticed that there's no wires going to either the front or rear brake. Where does the brake indicator tie into the electrical system to pop the light on? I figure my problem is going to lie somethere around there.
  • Nevco48
  • Nevco48's Avatar
Re: Brake light indicator
06 Jun 2006 04:25
#52468
The rear brake pedal should have a light weight spring attached that actuates a switch mounted on the frame. Front brake should have a switch mounted in the brake lever, or sometimes in a hose splitter block up on the trees, I'm not familiar with 650's...
  • DanOz7Five0
  • DanOz7Five0's Avatar
07 Jun 2006 20:01
#52779
I posted this last year. I havent solved the rpoblem yet, other than to make sure I use the back brake
kzrider.com/forum/viewthread.php?tid=28878
  • OKC_Kent
  • OKC_Kent's Avatar
07 Jun 2006 20:15
#52785
kc5deb
Please update your profile, you should have a signature that lists your location and bike model, year, etc
Nevco48 is right about the switch locations.
Cashion, OK
78 KZ650 B2 85,000+ miles
