plug wires...
  • lushbaugh
  • lushbaugh's Avatar Topic Author
  • everybodys a pro......
plug wires...
23 May 2012 13:35
#524258
im running dyna s with accel coils, do you guys run the factory resistor caps or bypass them and run car type plug wires. im on my second dyna s and when i put it in i replaced the 8.8 wires that arced and put the resistor caps on the wires i made to be safe till i poked around. i just think its odd that the unit failed. ive had great luck with dyna in the past but i figured id ask
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
