Engine idling high with light switch
  • Tabata
  • Tabata's Avatar Topic Author
23 May 2012 01:05
#524189
Whats up guys? Well i tried searching around but honestly, i am not quite sure what to search for. I have a 82 CSR 650. So here is the problem. When the bike is idling, I flip the headlight switch, and the revs jump up. When i first did it, it actually jumped up close to the red line and starting backfiring like a mofo. I currently have to start the bike with the battery charger/starter we have at work. Before i can switch the charger off when the bike starts, the engine revs are also high. As soon as i turn the charger off, the revs go back down to normal. What might cause this? I tried searching but i honestly dont know what i am searching for. Thanks in advance. Oh and if it makes any difference, although i dont see why, this is the first time i got it started. The carbs were completely gummed up and i finally got them clean. Started the bike up and this is what happened.
-Kyle
Here is a video of the problem
Bike reving up
1982 csr650
  • wireman
  • wireman's Avatar
Re: Engine idling high with light switch
23 May 2012 01:20
#524193
Id start with checking regulator/charging system B)
The following user(s) said Thank You: Tabata
  • Tabata
23 May 2012 01:56
#524200
Thanks a lot man. I ordered a new battery from Z1 so hopefully it gets here soon so i dont have to keep cranking the bike off the battery charger. I am scared i might have fried something while attempting to get the bike started. hopefully not though. Thanks again for the quick response.
1982 csr650
23 May 2012 09:57
#524237
I hope you haven't cooked the electrics on your bike, but for future reference do not use a battery charger to start your bike. You can start your bike by jumping it from a car battery with the car engine NOT running. Ed
  • loudhvx
  • loudhvx's Avatar
23 May 2012 13:11
#524250
The video sounds like you are running on two cylinders at idle. When it revs up it sounds like the other two cylinders start firing.
Either there is a wiring problem, or there is a voltage-related problem that is affecting the two non-firing cylinders.
  • Tabata
23 May 2012 16:28
#524292
Thanks guys. I will check all of that. I feel really dumb for not using a car battery. I work in a freakin garage for christ sake. >.> well hopefully the damage isnt to bad. Once i get the new battery I will let you guys know the deal with the regulator/charging systems and what not.
1982 csr650
