timing light going crazy
- zmaniscalco
22 May 2012 21:31
I am having a problem at low RPM’s with my spark, I set the timing but when it idles it looks like the spark goes from normal to 10x as fast and back down….. What the hell is going on?
Turbo, 1075 kit, accell coils and wires8.8, Dyna 2000
Added video
Added video
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- zmaniscalco
Re: timing light going crazy
22 May 2012 22:08
crap i mean a dyna s
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- bountyhunter
23 May 2012 01:30
Possible EMI noise triggering your light's sensor.
- Tomolu5
23 May 2012 06:49
Make sure your connections are good, and make sure your pick-up C.T. is as far as possible from the other plug wires
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- z1kzonly
23 May 2012 09:31
IGN. ADVANCE WEIGHT SPRINGS.
OVER 50% OF THE BIKES ON HERE ARE WORN OUT.
- zmaniscalco
24 May 2012 01:10 - 24 May 2012 01:46ok looks like a new timing advancer, or dyna 2000. I have sean a few treads about making a new spring????z1kzonly wrote: IGN. ADVANCE WEIGHT SPRINGS.
but I think it is time to save for the Dyna 2000, with a turbo I heard it works great. Just to nake sure that will replace the timing advancer right?
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
Last edit: 24 May 2012 01:46 by zmaniscalco.
- zmaniscalco
26 May 2012 22:14z1kzonly wrote: IGN. ADVANCE WEIGHT SPRINGS.
WOW, that was it, The old one was sticking and not snapping back, I pulled one out of my 78 engine that has been sitting for a while cleaned and greased...... and man that was my whole problem, I have had trouble with plugs foling, and I bet this is why. It runs stong and soild....
Thanks
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- spark23ca
26 May 2012 22:33its good to be right ..its the same as the old chevy's the most overlooked thing is the timing advancez1kzonly wrote: IGN. ADVANCE WEIGHT SPRINGS.
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
