80 kz750 ltd runs terrible after 10 miles
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
20 May 2012 03:15
#523495
1980 kz750 ltd 4, electronic ignition. Runs ten miles parked for an hour parked then runs horrible. Thursday I had to get it towed it seems like the 1-4 plugs were not getting any spark when I tested it the next day and now it is, it likes to buck when starting from a standstill. It does good after 3500 rpms all the time until now. Also has some serious fireballs from the exhaust. The valves seem to be in order, .08 (give or take a 0)or less. When it broke down the oil was really low. Any serious helpful help is seriously appreciated.
  • jess
  • jess's Avatar
Re: 80 kz750 ltd runs terrible after 10 miles
20 May 2012 04:19
#523499
Sounds like you need new coils.
When coils get hot they expand. There may be breaks in the windings, the breaks in the coils make
contact when cold. But as the coils warm up and expand the breaks lose contact. I have seen this
with many old bikes. It is very difficult to check a coil with this problem.
  • donthaveakawman
20 May 2012 22:28
#523664
oh great that's kinda what i had in mind, i don't think i can go around saying i told you so on this one because i didn't tell anyone about this, thank you for your help.
  • MFolks
  • MFolks's Avatar
20 May 2012 22:50
#523675
www.z1enterprises.com sells the Emgo coils along with the pricey Dyna coils. Another popular replacement is the Yellow 3 ohm Accel ignition coil.
  • donthaveakawman
25 Aug 2012 02:17
#544654
i also think a carburejet would be in order, i have a k&n drop in filter and a free flowing exhaust and i don't want to burn up my internal organs on the engine. i have polished the cooling fins for the most part on the engine, and already it runs better.
  • KZCool
  • KZCool's Avatar
27 Aug 2012 17:02
#545114
I had a simialr problem. Bike would start great everytime, but after it warmed up it ran like crap. Tested the coil (cool) and it was fine. I tested it warm one day and boom, found the problem. A new Dyna coil later and all is good, untill the more recent problem :P . Thats for a different forum though.
1976 KZ750 hardtail
  • apeman
  • apeman's Avatar
27 Aug 2012 17:38
#545124
Swap your coils, one side for the other. If the problem shifts to the other two cylinders, you know you have a bad coil that is faulting intermittently. If the problem remains on the original two cylinders, you know it is not the coil.
At that point my educated guess is you have a defective ignition pickup. (This has happened to me.) Swap another one in, and you will likely fix the problem.
Of course, make sure your connections and wiring are all good in the ignition circuits.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • donthaveakawman
15 Sep 2012 00:47
#548781
i got it now i found a loose wire from when i put my hei modules on the bike.
  • donthaveakawman
15 Sep 2012 00:48
#548782
donthaveakawman wrote: i got it now i found a loose wire from when i put my hei modules on the bike.
has anyone ever popped a wheelie on one of these?
  • bountyhunter
  • bountyhunter's Avatar
15 Sep 2012 01:25 - 15 Sep 2012 01:26
#548787
only on you tube.
Reminds me of the old joke:
What's a redneck's last words?
HEY! WATCH THIS!
An equally correct answer is:
SOMEBODY HOLD MY BEER....
Last edit: 15 Sep 2012 01:26 by bountyhunter.
