Dyna vs Accel Coils
19 May 2012 21:34 #523437 by ramtough_63
Dyna vs Accel Coils was created by ramtough_63
Like most people when I was in the market for a new set of coils I priced Dyna Coils after all I was running a dyna Ignition. I ultimately bought a set of Accel Coils. I Needed a set and a member had em for a price I couldnt refuse.
The Accel are more expensive than the Dyna so i am wondering is that why most people run the dyna's??
or is it because they are the match to their ignition?
does anyone have an opinion on which one is better? (if there is such a thing)
any pros and con comments welcome. just curious on any differences anyons has found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
19 May 2012 22:04 #523444 by Powerstroke_fan
Replied by Powerstroke_fan on topic Dyna vs Accel Coils
I think i remember reading about this topic on here before id do some searching to see what comes up.If i remember right i think they were leaning towards the accels.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
19 May 2012 22:50 #523457 by roy-b-boy-b
Replied by roy-b-boy-b on topic Dyna vs Accel Coils
The 3 ohm Dyna will match your bike. That would be worth 3 hp. !
  • 4TheKZ1000
  • Visitor
19 May 2012 23:19 #523463 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Dyna vs Accel Coils
run what you can get-got and run it hard.
19 May 2012 23:29 #523465 by ramtough_63
Replied by ramtough_63 on topic Dyna vs Accel Coils
that was my thinking buyin g new i would've bought the dyna but i got a deal on the accels so i'm gonna twist her and go.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
20 May 2012 00:22 #523477 by loudhvx
Replied by loudhvx on topic Dyna vs Accel Coils
The Accels are more expensive because they come with more stuff: wires, mounting brackets, anvil for custom making the wires. As long as you are comparing 3-ohm Dyna with 3-ohm Accels, they are pretty similar and you probably won't be able to tell them apart in performance.
20 May 2012 00:33 #523479 by Patton
Replied by Patton on topic Dyna vs Accel Coils
Would measure resistance of primary windings on the Accel coils to assure not less than 3Ω.
3Ω would match resistance of the green Dyna coils compatible with Dyna-S ignition.
(Use an ohmmeter with probes touching the primary terminals.)
Good Fortune! :)
20 May 2012 09:36 #523515 by Old Man Rock
Replied by Old Man Rock on topic Dyna vs Accel Coils
"anvil for custom making the wires"... :laugh: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
20 May 2012 12:18 - 20 May 2012 12:19 #523535 by loudhvx
Old Man Rock wrote: "anvil for custom making the wires"... :laugh: :laugh: :laugh: :laugh:
:laugh: Hey don't laugh, it's a legit tool. :laugh:
Actually, you get two in the kit. I've thought of welding them to a broken bolt cutter to make a decent crimper for 9mm wires.
Last edit: 20 May 2012 12:19 by loudhvx.
23 May 2012 04:52 #524208 by roktempt
Replied by roktempt on topic Dyna vs Accel Coils
Thanks for sharing this .Will you upload some images.
  • Motor Head
23 May 2012 09:36 #524231 by Motor Head
Replied by Motor Head on topic Dyna vs Accel Coils
Also the mounting, no terminal close to the mounting on the Accel. So no messing around, just bolt them on. Accel coils do come with suppression core wires, which could be eliminated for a hotter spark, but with possible interference being the result.
