Wiring a KZ1000P, need help.
  • MtStateMike
  • MtStateMike's Avatar Topic Author
19 May 2012 15:33
#523383
I was riding my kz1000 last Tuesday and lost all juice to everything, except a few that were hardwired to the battery. Found the 30 amp fuse was blown, replaced it and still nothing.
Anyhow I would love to just wire exactly what I need for the ignition, starter, headlight, taillight, brake light and blinkers. My problem is the previous owner had wired around some of the original wiring harness instead of fixing the issue. So I have no idea what goes to where because they just used red, white or black.
If I knew what the connectors that plug into the box by the battery went too, it would make things alot easier. Like which one do I need to get the basic wiring I want to do done. Also I have had problems finding the starter relay, rectifier, breaker points then I think I could get the job done.
If anyone has any ideas or diagrams of where parts are located and diagram of where the colored connectors go to on the side of the battery box, I would greatly appreciate it.
Thanks
92 KZ1000p
Lumberport, WV
  • Kawickrice
  • Kawickrice's Avatar
Re: Wiring a KZ1000P, need help.
19 May 2012 15:59
#523390
I doubt the bike is running points, probably electronic. Trace the big hot wire from the battery to find your starter relay. The rectifier is integrated into the voltage regulator which is usually mounted to the underside of the battery box.
You will need the factory diagram so you can cipher wire colors and where they go
Someone else will chime in on things I missed but this is the general areas to check
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • MFolks
  • MFolks's Avatar
19 May 2012 18:43
#523415
Here ya go : www.cyclepsycho.com/kz1000p/kz1000p.html If information about tools and supplies is needed, just send me a private message.
