FRIED WIRES PLEASE HELP
  • at20
  • at20's Avatar Topic Author
18 May 2012 21:05
#523232
i installed a new battery on my kz400 today and as soon as i tried to connect the battery i had wires the went up in smoke. from the looks of it one of the wires coming from the starter relay fried and a few coming from the rectifier. i plan on wiring the bad section that melted with 10 gauge wire because it looks stronger then what was there.
can someone please tell me why this happened and what i might need to replace so it wont happen again.
1976 kz400
  • ramtough_63
  • ramtough_63's Avatar
Re: FRIED WIRES PLEASE HELP
18 May 2012 22:03
#523245
anytime i have had a melt down when istalling a battery was because i reversed the polls or shorted across the pos with my tools never had a mechanical reason.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • Kawickrice
  • Kawickrice's Avatar
18 May 2012 22:45
#523250
Something grounded out causing the release of the factory smoke in the wiring harness. If you could not recover the factory smoke you will have to rewire it. :silly: Might check on getting a used harness if the damage was extensive.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • at20
19 May 2012 04:09
#523297
Well that's what I didn't understand. All I did was take the old battery out and put a new one in as soon as I hooked up the cables I got a spark and a huge cloud of smoke. 4 wires must melted like It was nothing. Could it be that it was just a bad fuse or wire and the new battery just over done it
1976 kz400
  • jeffasaki
  • jeffasaki's Avatar
19 May 2012 06:02
#523301
the only thing that can cause what you are describing is a dead short from the positive to the ground
you may get lucky and find it and just insulate it but it sound much more like a seriuos burn then that
take a multi meter and touch one end to the positive side (without the battery of corse)and trace the short with the negative side
GOOD LUCK
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • at20
19 May 2012 09:09
#523315
That's the thing I didn't have the problem before. My only issue was my battery was old so I bought a new. That's the only thing i did
1976 kz400
  • Motor Head
  • Motor Head's Avatar
19 May 2012 10:04
#523328
Do check to make sure the battery has been charged to the correct polarity, its rare but it can be reversed. Otherwise as mentioned you hooked up incorrectly.
  • at20
19 May 2012 19:05
#523419
Well u were right the new battery changed the post and me be over excited about riding I didny even pay attention to it. But its all rewired and running. But after a few minutes of running I lose power and my battery dies. I start back up with a jump but I die after a few minutes I die again. All my wiring is hooked up right. Is this a bad voltage regulator or a rectifier.
1976 kz400
  • MFolks
  • MFolks's Avatar
19 May 2012 19:11
#523421
  • MFolks
  • MFolks's Avatar
19 May 2012 19:13
#523422
A good website for the 400/440 twin bikes: www.armbell.com/forum/viewforum.php?f=17&mforum=kz400
  • Kawickrice
19 May 2012 20:46
#523429
Sounds like you fried the voltage regulator.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • at20
10 Jun 2012 19:25
#528017
well i followed the falut finding chart and all signs points to the stator.
now the new problem i order a stator and installed it with another new battery but after doing the test again from the fault finding chart it still points back to the stator. i have no idea why. one thing i did notice is that well when i connected a MM to the battery with the bike off my battery starts to drain fast but when i unplug the 3 yellow wired plug coming from the stator the MM shows my battery charging back up on its own but as long as i have the 3 yellow wires coming from the stator plugged up my battery drains FAST... i have know idea why this happening . also i noticed as soon as i turn the key on my battery drains.
any help ideas?????????
1976 kz400
