Battery time
  • mvent
  • mvent's Avatar Topic Author
Battery time
17 May 2012 21:09
#522991
Going to purchase a new battery for my 78 1000 A2A, looking for sealed because I'm scared to hell of acid dripping on my freshly painted frame, want direct bolt in, is the Yuasa super sealed maintenance free a good choice? Remember reading that possibly a Harley V Rod battery might fit. Any recommendations?
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • MFolks
  • MFolks's Avatar
Re: Battery time
17 May 2012 23:16
#523017
  • RonKZ650
  • RonKZ650's Avatar
Re: Battery time
18 May 2012 11:57
#523108
Yuasa is always a great choice. They don't make many sealed batterys for older motorcycles though, but they do make one for the KZ1000. Shorai is too dang expensive for what good they accomplish in my opinion. Last battery I got was called Motobatt for the KZ650 and I really like it. They make a battery for most any motorcycle and cost $50-$100 depending on model. Some things I like about it is it comes charged, no need to charge before use, terminals are on both sides of the battery and L adapters included, so one battery can be used in place of 10 yuasa designs. Another neat thing is the terminals of the battery that you screw your cables too are recessed in the battery case so screws directly thread into the battery. No more square piece of crap nuts that fall out, fall down out of reach like Yuasa use.
  • BohicaBob
  • BohicaBob's Avatar
Re: Battery time
18 May 2012 17:50
#523190
Tried a Westco AGM battery several years ago. It lasted 3 years on my '78 KZ1000/A2. Replaced this Westco battery today with a Scorpion AGM battery today. The Scorpion is less expensive than the Westco - I will see how long it lasts on this bike.
Was burned by Yuasa batteries: I was left on the road on two separate occasions by this fine brand made in Reading, PA: Once during Bike Week at Daytona right in front of the track in fact and once as I left from work. By the way, the second time it was a Yuasa-made Sears Die(Easy)Hard battery. ;)
Looked into Shorai batteries recently but I too found them too expensive at this time.
Re: Battery time
18 May 2012 18:48
#523204
I've always used plain old lead/acid Sears Die Hard batteries. In my KZ650-C1 they last about 6 years or so. I run my bike for 15 - 20 minutes at least every 3 weeks in the winter; I suspect if I didn't they might not last as long unless I loosened up my wallet and bought a Battery-Tender. :laugh: Ed
  • bountyhunter
  • bountyhunter's Avatar
Re: Battery time
18 May 2012 19:36 - 18 May 2012 19:36
#523212
mvent wrote: Going to purchase a new battery for my 78 1000 A2A, looking for sealed because I'm scared to hell of acid dripping on my freshly painted frame, want direct bolt in, is the Yuasa super sealed maintenance free a good choice? Remember reading that possibly a Harley V Rod battery might fit. Any recommendations?
Mike
I use a standard battery with liquid electrolyte, it has an overflow tube that exits low by the center stand pivot.
Last edit: 18 May 2012 19:36 by bountyhunter.
  • bountyhunter
Re: Battery time
18 May 2012 19:37
#523213
650ed wrote: I've always used plain old lead/acid Sears Die Hard batteries. In my KZ650-C1 they last about 6 years or so. I run my bike for 15 - 20 minutes at least every 3 weeks in the winter; I suspect if I didn't they might not last as long unless I loosened up my wallet and bought a Battery-Tender. :laugh: Ed
I see them at Harbor Freight on sale for about $5.....
  • mvent
Re: Battery time
19 May 2012 22:16
#523449
Ordered Yuasa maintenance free sealed battery, should have it in a few days, thanks for suggestions.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • RonKZ650
  • RonKZ650's Avatar
Re: Battery time
20 May 2012 00:59
#523482
Good choice. Running an old water fill battery is no longer an option for me. Them things flat suck, just like points ignition vs electronic. 1950s technology and that is being generous, more like 1920 Model A technology, but chain drive is 1920 technology too. Well, chains can go to hell along with watered batterys. :)
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Battery time
20 May 2012 12:48
#523545
Not that it matters for you.... but for others...
Via Battery Plus stores...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • loudhvx
  • loudhvx's Avatar
Re: Battery time
20 May 2012 12:54
#523546
RonKZ650 wrote: Good choice. Running an old water fill battery is no longer an option for me. Them things flat suck, just like points ignition vs electronic. 1950s technology and that is being generous, more like 1920 Model A technology, but chain drive is 1920 technology too. Well, chains can go to hell along with watered batterys. :)
:woohoo:
  • steell
  • steell's Avatar
Re: Battery time
20 May 2012 15:39 - 20 May 2012 15:42
#523575
Look at you! Get a fancy new bike and now you're spoiled rotten!!! :laugh:
I have a LiFePO battery in my 750 twin and it seems to be working fine so far.
Bought two of them for ~ $170 delivered from Alien Motion.
Last edit: 20 May 2012 15:42 by steell.
