Installing a Dyna S on my Kz1000
  • Ogcoda
  • Ogcoda's Avatar Topic Author
  • Killing Everything
16 May 2012 15:53
#522723
So I just got my Dyna S and have already removed my old points system off my bike. I started reading the instructions and found out that this might be a little harder then i had figured.... The instuctions are super confusing and I'm not very good with this kinda stuff in the first place. Anyone have some tips or tricks for getting this beast set up and timed right?
1978 kz1000 Bobber
2006 MazdaSpeed6
  • Kawickrice
  • Kawickrice's Avatar
Re: Installing a Dyna S on my Kz1000
16 May 2012 19:47
#522759
You should do a search as this has been covered before with good pics and detailed instructions. It would be quicker to do a search than it would be to retype it minus pics.
What part of the installation has you stumped? It is not super complicated but I agree that the instructions leave a lot to be desired
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Ogcoda
16 May 2012 22:33
#522796
well kinda the whole thing... I have searched a few times and couldn't find what i was looking for. I need help on the whole deal setting timing and all!
1978 kz1000 Bobber
2006 MazdaSpeed6
  • Motor Head
  • Motor Head's Avatar
16 May 2012 22:37
#522797
Kawickrice wrote: You should do a search as this has been covered before with good pics and detailed instructions. It would be quicker to do a search than it would be to retype it minus pics.
kzrider.com/index.php?option=com_user&vi...bGxhdGlvbi1ieS1vbXI=
  • Ogcoda
17 May 2012 01:23
#522846
alright, so i followed the instructions and this is what my problem is now....
I have it hooked up just as it said to and I'm not getting the 12v light to turn on at all. So thinking i must have mested up somewhere i unhooked the red connector to try it again, and the light came on.... BUT it stays on no matter where the timing is. :blink: And if i plug it back in to where it was before(Yellow/Red Wire) It shuts the 12v light off. Any ideas guys?
1978 kz1000 Bobber
2006 MazdaSpeed6
  • Old Man Rock
  • Old Man Rock's Avatar
17 May 2012 09:31 - 17 May 2012 09:45
#522880
Are you following this.... dyna-s-ds2-1-installation-by-omr
Wiring Diagram...
NOTE: For the DYNA IE to operate, the ENGINE must be grounded!
In reference to switched battery voltage (~ +12Vdc), the ignition plate is grounded through the engine mounting.
Attachment DynaSBenchTest.JPG not found
Rotor Magnet facing 1/4 @ TDC...?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 17 May 2012 09:45 by Old Man Rock.
  • Motor Head
17 May 2012 09:36
#522882
www.dynaonline.com/skins/downloads/Default.aspx
Download the Dyna S testing pdf file from Dyna's web site. it will explain how to check it as you are installing.
