1981 kz1100 wiring diagram for speedo, tach, fuel
- 1100fighter
15 May 2012 12:57
Does anyone have a diagram for a 1981 kz1100 that shows what each color wire is for speedo, tach, and fuel gauge? I have a new koso gauge and I am trying to wire it to the factory gauge connectors? I have a diagram that shows wire flow but not which wire controls what. A list would work fine too.
Thanks
Thanks
Throttle junkie since 5
- MFolks
Re: 1981 kz1100 wiring diagram for speedo, tach, fuel
16 May 2012 13:24
Let's try the following color codes:
TACOMETER (has a six pin connector with three pins
BLack
Brown
Black with yellow stripe.
SPEEDOMETER has a six pin connector
Black
black with yellow stripe
Orange (Goes the to the speedometer instrument)
BLack
Brown
Black
16 May 2012 13:39 - 16 May 2012 13:41
These wiring diagrams from KZr's FILEBASE are in color, showing which wire goes to which component.
Click > www.kzrider.com/filebase/doc_download/270-z1100a1
Click > www.kzrider.com/filebase/doc_download/257-z1100b1
FILEBASE is loaded with all kinds of neat stuff.
Attachment filebasekzr.jpg not found
Last edit: 16 May 2012 13:41 by Patton.
- 1100fighter
16 May 2012 17:20
Thanks Patton. I have them all figured out now except which hot wire would be the best source for my main power?
- 1100fighter
20 May 2012 00:21
I figured it out. White w blue stripe is 12+ brown is ign powered 12+. I posted all the wiring in my build thread in projects.
