Location of Speed Sensor on my 82 KZ1000J
- virtualtoad
14 May 2012 22:44 - 14 May 2012 22:47
So I'm in the middle of a complete re-wire, and I found a pair of wires that was run to the left-side of the frame, to something mounted right at the rear axle.
Unfortunately, the previous hack-job resulted in the other end of the wire to be left unterminated, so I can't know what it went to, and I'm unfamiliar with the device.
Is that the speed sensor?
Last edit: 14 May 2012 22:47 by virtualtoad.
Re: Location of Speed Sensor on my 82 KZ1000J
14 May 2012 23:08
- MFolks
14 May 2012 23:38
Most speed sensors are mounted on the front forks, with magnets being used to trigger the sensor, I've never seen any on the rear wheel(might be an after market installation).
The following user(s) said Thank You: virtualtoad
- virtualtoad
14 May 2012 23:47
well that clinches it.. found the magnet. thats definitely the speed sensor.
thanks!
thanks!
