Help! '76 KZ900 Tail Light Stays On
  • WhatTheFlyinFudge
  • WhatTheFlyinFudge's Avatar Topic Author
14 May 2012 10:57
#522265
Hi All,
I'm a motorcycle/mechanics newbie, and I need what may be some basic electrical help:
Yesterday, I got my 1976 KZ900 A4 out of storage for the winter, and installed a new battery. After sucessfully starting & running the bike for about 60 miles, I parked the bike for the day when I noticed the tail light remained on after shutting the bike off.
Back when I installed the battery, I snuck a long phillips screwdriver down between some red & black wires to reach the battery's negative wire mount. My thought is I might have disturbed the wires I snuck the screwdriver past and caused a short of some kind.
Here's what I did to troubleshoot so far: I removed the main fuse, and the tail light turned off (removing the tail light fuse didn't turn the tail light off).
At this point, I need to pop the main fuse back in for the lights to work. A temporary solution at best :/
Any thoughts on how to proceed/troubleshoot? Again, I'm a complete newbie here.
Thanks in advance for any advice!
Cheers,
Andy
1976 KZ900
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Help! '76 KZ900 Tail Light Stays On
14 May 2012 11:44
#522272
Check the switch by the rear brake pedal. Insert fuse and lift up on the spring. Check front switch by inserting fuse and disconnecting one wire. Roy
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
14 May 2012 14:34 - 14 May 2012 14:36
#522304
WhatTheFlyinFudge, Welcome.
The ignition switch has a parking light function (rear tail lamp on, ignition off, key removed).
If you turned the ignition off clockwise(to the right)this activates it. Off (no light) is to the left.
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Last edit: 14 May 2012 14:36 by Rainman.
  • WhatTheFlyinFudge
14 May 2012 18:27
#522345
Holy crap, you could be a genius. I could also be an idiot. I do remember turing the key all the way to the right before removing it.
I think it's time for me to get the KZ900 Clymer manual and study the shit out of it.
Thanks Jim!
1976 KZ900
  • Rainman
  • Rainman's Avatar
15 May 2012 14:51
#522523
As I had done the same thing, I fall closer to the second catagory than the first. Keeping old motorcycles running gives plenty of opportunity to prove such.
A factory service manual is a better choice than aftermarket. Ebay or check the KZ tab at the top of the page. May be an electronic copy available.
Check out the KZR Relay Ride East Coast post and join in if you are so inclined. It is in the Conn. area now and heading to Maine.
Jim
Jim
Quincy,IL
  • JR
  • JR's Avatar
15 May 2012 20:29
#522579
Rainman wrote: WhatTheFlyinFudge, Welcome.
Jim
When I first got my 750 I ran the battery flat doing that. Doh !
:laugh: :laugh: :laugh: :laugh:
  • WhatTheFlyinFudge
16 May 2012 12:56
#522703
Guys,
It was the parking light function. Battery is SAVED.
Thanks a million for the help!
1976 KZ900
