Similar Wiring Harness?
- adr3naline
12 May 2012 02:37
Which other models would have a similar wiring harness to the 1979 KZ650sr (D2)? The previous owner of this bike chopped up this harness more than I thought when I was expecting the bike before I bought it. There's a couple 1979 harnesses on ebay, but I'd like to have more options if possible.
In general, which years are the most similar to the 1979 that I can use to find more parts?
Thanks!
Thanks!
adr3naline
1979 KZ650sr
1979 CB650
1979 KZ650sr
1979 CB650
- Kawickrice
Re: Similar Wiring Harness?
12 May 2012 03:10
I think you can go to Kawasaki.com. You can find out what parts are interchangeable, and what fits what. Exploded views, part numbers, very informational.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- BikeDude2002
- Today is a good day to ride...
14 May 2012 00:40
Unfortunately, I don't think you are going to find a really close harness to replace your main harness on your D2. Although, all of the main harnesses of this era are similar, none will but a direct 'plug n play' kind of replacement. Be advised, although the Kawasaki website is useful, it is not completely accurate. For instance, the Kawasaki site shows the D1 and the D2 as using the same part number. In reality, although these two models are electrically similar, there are important changes to the ignition switch (different wiring) and a change to several connectors - these 2 bikes do not have interchangeable main harnesses. Might want to contact
www.cwswiring.com
for a all new harness made for your model bike and substantial upgrades! :woohoo:
78 KZ650 SR
90 Yamaha Radian
90 Yamaha Radian
The following user(s) said Thank You: adr3naline
- Kawickrice
14 May 2012 13:07
I rewired a KZ900 with a KZ400 harness. :blush:
Depends on how dirty you want to get. Any 650 harness of same year will get you in the ballpark. Most harnesses will be very close as far as connectors and colors. A stripped down model from the factory usually uses the same harness as the loaded model,(Suzuki does this) extra wires are common because of this reason. Makes sense from a manufacturing standpoint.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
