Battery Not charging. HELP
  • dano83-1100
  • dano83-1100's Avatar Topic Author
  • 1983 KZ1100 LTD
11 May 2012 08:24 - 11 May 2012 08:26
#521491
Long story short...I was riding, I noticed the directionals first flashing very slowly and then not at all. Pulled in the clutch at a stop sign and no power when I hit the starter it went click click. Dead battery. :angry: Bump started going down hill but would be only run until you have to pull the clutch...then she stops and no power to start. pushed it a mile home...got sunburn and more exercise than I planned on. :angry:
I think it's the regulator/rectifier but how do I know fer sure? any help Would be most appreciated.
Bike is 1983 KZ1100 ltd.
Last edit: 11 May 2012 08:26 by dano83-1100.
Re: Battery Not charging. HELP
11 May 2012 08:27
#521492
The Kawasaki Service Manual describes a series of tests for each of the electrical components. Ed
The following user(s) said Thank You: dano83-1100
  • Motor Head
  • Motor Head's Avatar
11 May 2012 11:45
#521529
650ed has it, the Factory Service Manual will walk you through a series of tests for the charging system. There was a Downloadable link to the FSM for your bike, but its been disabled. If you don't have a FSM for your bike, then someone can post up some of the info more than likely.
  • MFolks
  • MFolks's Avatar
11 May 2012 14:39
#521571
If possible, fully charge the battery, and with the engine warmed up, put a multimeter on the battery terminals with 4000 rpm on the tach. you should see 14.5 volts. If a lot less(like 10 or so) look further, as it could be a lost phase of the three phase alternator,loose/corroded wiring at the regulator/rectifier connector,or like you mentioned, the regulator/rectifier has failed.
Here's a troubleshooting guide: www.electrosport.com/technical-resources.../fault-finding-guide
  • dano83-1100
  • 1983 KZ1100 LTD
12 May 2012 10:24
#521766
What if I just replace both the stator and the regulator/rectifier? Would this be problem solved either way?
  • Old Man Rock
  • Old Man Rock's Avatar
12 May 2012 10:42
#521773
Possibly but most likely not.... :S
Here's why I say this...
You can replace these items for a couple hunksies ($$$) and still have the problem only to find out it was a corroded connection, missed ground, broken conductor for current path etc....
Do yourself a HUGE favor, get the manual as mentioned... It provides step by step logical troubleshooting guides using a DVM in diagnosing & finding the real culprit in your charging system problem.
Outside of this issue, the manuals are a must. There's not an experienced guy /gal on this forum who don't have multiple manuals for their rides... ;)
You think we do all these rebuilds by memory.... :whistle: No freaking way...
Hell I can't even remember if I put skivies on this morning.... :pinch: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • MFolks
  • MFolks's Avatar
12 May 2012 13:33
#521806
The best way to fix this problem, is to figure out what's causing it, rather than throwing money at it. As mentioned, get a manual,a multimeter, and a place to work on your bike. Troubleshooting is a step by step, logical process, that really can't be rushed.
  • MFolks
  • MFolks's Avatar
12 May 2012 13:38
#521807
The following post covers testing and replacement of an alternator stator(the wire windings).
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s ,GPz1100’s
And possibly the 750’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3, 2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!!
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced. Some of the older Z1’s and KZ900’s were reported to be phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement. Also check from any of the three YELLOW wires to ground, this will show if arcing took place. Check only with the engine off !!
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty.
Inspect the wiring for signs of shorting or overheating too. www.z1enterprises.com sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover will have to be removed to access the electrical connectors coming from the alternator, the left foot peg assembly and shifting lever will have to come off also.
Alternator Stator Replacement On the Older 4’s
Source for replacement Stators
A. www.electrosport.com/technical-resources.../fault-finding-guide
B. www.customrewind.com
C. www.rmstator.com
D. www.regulatorrectifier.com
E. www.oregonmotorcycleparts.com (Rectifier/ Regulators Only)
1. If by testing either by checking the output voltage from the stator or by using and ohmmeter for resistance and the stator is determined to be bad, replacing the stator is not a difficult job.
2. The motorcycle owner should have on hand a replacement alternator gasket as it will tear on removal and leak if reused.
3. Put the bike on the center stand if possible and lean it to the right to minimize the oil volume that could come out when the alternator cover is removed.
4. Have selection of Metric wrenches and sockets along with Metric Allen keys to be able to accomplish this repair. ¼" and 3/8" ratchets and extensions may be needed along with Allen bits.
5. Remove the gear shift lever, the sprocket cover and possibly the left foot peg assembly.
6. A catch pan for what little oil will be lost should be positioned under the alternator on the left side. Newspapers will soak up any oil lost or some kitty litter will do as an absorbent.
7. Remove the alternator cover fasteners, some bikes use a socket head cap screw(Allen type) and others use the Phillips head type, the #3 screwdriver bit fits best for those. Use a small dish or can to collect the removed fasteners from the parts to prevent loss/damage.
8. The alternator stator is secured to the inside of the cover usually with three Allen headed bolts, Some bikes may have Torx style fasteners, Remove them and disconnect the three yellow wires that have bullet connectors on them from the bundled wires inside the sprocket cover.
9. If your bike has some color other than yellow for the alternator output wires, make note of what goes where as the older Kawasaki’s were phase sensitive in regard to the regulator/rectifiers.
10. When installing the replacement stator, clock or position the output wires and grommet so they fit into the small port under the alternator cover without being pinched or damaged.
11. Tighten the three Allen or Torx fasteners, securing the replacement stator to the cover. I like using the BLUE Loctite # 242 for hardware that can be removed with hand tools.
12. Remove the old gasket from the mating surfaces of the alternator cover and engine case by scraping with a piece of sharpened plastic like Lexan or Plexi-glass as these will not gouge the soft Aluminum Cases. Avoid using a metal gasket scraper for this.
13. Position the alternator cover, checking for pinched wiring and install the fasteners with a little silver anti-seize on the threads, tightening to the correct torque.
14. Connect up the output wires to the mating female bullet connectors and while you’re in there, check the routing of the wire bundle that runs through there.
15. Inspect for signs of heat damage to the wire insulation and vibration damage too.
16. The side stand switch, neutral switch, and oil pressure switch wiring are all bundled with the alternator output wiring running above and behind the engine output sprocket. This bundle runs in a channel as it goes up toward the various electrical connections.
17. The regulator/rectifier plug on the 80’s bikes usually has six wires in it:
A. One (1)WHITE with RED stripe, this is the bikes main power wire usually 12 gauge in size.
B. One(1) smaller Brown wire, probably 18 gauge or so, the voltage sense wire for the regulator/rectifier, helps keeping it from overcharging the battery.
C. One(1) BLACK with YELLOW stripe wire, part of the ground circuits, maybe 16 gauge in size.
D. Three(3) YELLOW wires, maybe 14 gauge in size, the alternator output wires going to the regulator/rectifier which converts the Alternating Current(A.C.) to Direct Current(D.C.) using rectification, producing the power to run the motorcycle and charge the battery.
18. Reinstall the sprocket cover, again checking for pinched wires before tightening. Install the shifter on it’s splined shaft checking for proper location, and the left side foot peg assembly.
19. Except for the minor oil spill and reluctant fasteners, it’s not a very difficult job to do.
  • dano83-1100
  • 1983 KZ1100 LTD
14 May 2012 09:53
#522255
I want to thank all of you for your advice and help. It is really appreciated. I'm not much a wrench, I can turn a bolt or two, change oil, spark plugs, battery, minor stuff, but I am not a very good trouble shooter.
I'm confident that with your help my bike will be up and runnin' in no time. The battery is currently being charged, so tonight starts a new adventure for me. B)
