Help..78 kz650 wont start
  • vondikka
  • vondikka's Avatar Topic Author
11 May 2012 02:08
#521451
I just bought a 78 kz650. Previous owner said he had put new plugs and battery. When i went to check it out, the guy had the battery charging and then started it up. It ran great when I test drove it. Then i brought it home on a truck and tried to start it but it would only turn over. both electronic ignition and kickstarter wouldn't start it. I charged the battery for 6 hrs.still no start. Fluid levels in batteryare fine. Please help me out if u can, i'm a newbie when it comes to motorcycles.
78 KZ650 C2
76 kz400 D3
Re: Help..78 kz650 wont start
11 May 2012 09:19
#521507
When you try to start it remember - key on; tranny in neutral; pull in clutch if using electric starter; NO THROTTLE; CHOKE ON FULL. Ed
  • rstnick
  • rstnick's Avatar
12 May 2012 00:08 - 12 May 2012 00:11
#521702
First set fuel petcock to Prime to fill the carbs for a few minutes.
Then:
key on; kill switch ON; tranny in neutral; pull in clutch if using electric starter; NO THROTTLE; CHOKE ON FULL.
If still not starting, then pull each plug out, checking for any gas on plug. If there's gas, that's good, if not, then you need to check out why there's no gas. Carb issues?
Reattach each plug to their spark plug caps and lay the plugs on the engine, metal to metal.
Tuorn on the bike and use the starter to turn over the engine.
Do you have spark on all 4 plugs? If yes, then great. If not, then you have electrical issues.
Start there, and report back. ;)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 12 May 2012 00:11 by rstnick.
  • vondikka
12 May 2012 00:52
#521716
ok, i dont have spark. i checked like u said and didn't see anything. i read that it could be the points and condenser, is that correct?
78 KZ650 C2
76 kz400 D3
  • elfmagic17
  • elfmagic17's Avatar
12 May 2012 01:31
#521726
Silly question but is the kill switch on the handlebar control in the "on" position? I've done that before and felt so stupid afterwords.
Kenny Hicks
74 Honda CB550
  • Prophis
  • Prophis's Avatar
12 May 2012 02:09 - 12 May 2012 02:10
#521731
make sure you;re fuel line is set to on, engine kill switch disabled, & DON'T hold clutch when kickstarting. when i first got my bike i kept doing that and didn;t know what was up. My electric start isnt working right now, so dunno about holding the clutch for that.
TIP: Try spraying starter fluid in in/at the carb filters back of the engine. SOMETIMES that is all my 77 kz650 needs to turn over.
hope that helps, congrats on the new bike. KZ's rule!
Last edit: 12 May 2012 02:10 by Prophis.
  • vondikka
12 May 2012 02:50
#521735
yeah, ive followed all of the corrrect starting procedures but still no start. it does turn over though. kickstarter wont start it either. And it is getting fuel at the petcock & float bowl. no spark, (as far as i can tell) I tested for spark as directed, didn't see any spark.
78 KZ650 C2
76 kz400 D3
  • Old Man Rock
  • Old Man Rock's Avatar
12 May 2012 11:06 - 12 May 2012 11:08
#521780
KZ650 site... ;) They have a later model OEM manual for the KZ650 series...
KZ650 Site...
Should be close enough to what you have for discussion...
1) As depicted in the image, do you have measured Battery voltage (~+12Vdc) coming out the the right hand handle bar switch to the coils...?
2) Insure engine is truly at ground potential to battery (-) ground.
3) Verify points/condensor or EI is operating to specifications.
Not sure of the accuracy of this diagram but....
1978 KZ650-B2
Attachment KZ650-B2C21978.jpg not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 12 May 2012 11:08 by Old Man Rock.
  • vondikka
16 May 2012 22:15
#522790
so i got a set of feeler gauges and a factory manual, adjusted the point gap accordingly, bike started right up! Awesome!
78 KZ650 C2
76 kz400 D3
  • rstnick
  • rstnick's Avatar
18 May 2012 16:55
#523177
Good to hear!
You should go through all the items in the periodic maintenance chart, and get some new tires if their older than 5 years old.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
